351m timing help?
Old May 28, 2010 | 09:56 AM
wheelhoppin67's Avatar
wheelhoppin67
351m timing help?
I know the timing is off on my 78 f150 with a 351m AT, and my emmison sticker is gone of the valve cover, ive heard timing is suppose to be set at 10 degrees and/or 14 degrees, any help is appreciated as to what its suppose to be set at, thanks
Old May 28, 2010 | 11:49 AM
tinaheels's Avatar
tinaheels
12 degrees btdc
Old May 28, 2010 | 05:02 PM
Joseph69's Avatar
Joseph69
10, 12 14, 43. You can set the timing two other ways. Set it by vacuum. When you get the highest vacuum at idle. Or a PITA way. Set it advanced so it "pings" a little then back it down.
Pinging is bad and will burn a hole in the piston eventually, called predetination. But back it down a little and you will have the best advance for power. Mine will ping a little when I first get on it and it runs like a cat with a turpentined a$$.
Old May 28, 2010 | 05:59 PM
vtjvt's Avatar
vtjvt
Mine is set a 14, Just play around with a few differant settings and see what runs best for you and your driving style.
Old May 28, 2010 | 06:19 PM
fmc400's Avatar
fmc400
MSEE
Don't set timing with a vacuum gauge. It can come out too far advanced. A timing light is the proper tool for setting timing.
Old Jun 7, 2010 | 10:18 AM
wheelhoppin67
Thanks for the info its set at 14 right now and was way over 20 when i got the truck, its runs pretty good still have a little skip on highway and wants to diesel when i shut it off sometimes.
1979 300i6
Jan 26, 2015 04:07 PM
jonny.redneck
May 4, 2014 08:04 AM
MikePacey
Mar 10, 2011 04:43 PM
Powerstrokin_350
Jul 9, 2010 01:00 PM
thelonerangerxlt
Feb 2, 2004 09:41 PM
