6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
dpf delete and engine failure... Anyone?
Old Jun 7, 2010 | 02:51 PM
mhaas59's Avatar
mhaas59
MY ENGINE FAILURE WAS NOT CAUSED BUY MY MODES .IT MOST LIKELY BECAUSE IT HAD OVER 300,000 ON IT AND IM NOT YELLING
Old Jun 7, 2010 | 04:41 PM
jboczar's Avatar
jboczar
Deleting dpf should have nothing to do with engine failure rates. Ford sells these same engines in other countries that do not have such strict emissions laws meaning they don't come with dpf's. Deleting a exhaust treatment will have no bearing on engine performance or longevity.
Old Jun 7, 2010 | 06:17 PM
DSTRBD's Avatar
DSTRBD
Former Vendor
Engine failures are very rare on the 6.4L even when heavily modded. The only one I have heard about is from extreme abuse.
Old Jun 7, 2010 | 09:07 PM
BLK94F150's Avatar
BLK94F150
We had a very early 08 melt down. It was a very busy ambulance. We lost a turbo and had a ton of regens though early on. When the engine went it took another turbo and they replaced the DPF.
Thinking about it though there is a good chance that it ate a ton of LSD. We have our own fuel pumps and I highly doubt that they flushed and cleaned out the LSD before the ULSD went in. Since then no problems and also since the ULSD we have had much less problems with our 6.0s. I'm thinking that the DPF got clogged up and the heat built up.
Mike
Old Jun 7, 2010 | 09:13 PM
Tom's Avatar
Tom
Mike
Glad to hear your luck has been better! I remember a year or so ago you didn't have much positive to say about your 6.4L ambulances!
Old Jun 7, 2010 | 09:23 PM
BLK94F150's Avatar
BLK94F150
It was not a pretty start and changing out squads is a huge PITA. I really think ULSD has been the cause of our fleet reliability going way up. I think the decrease in lubricity is a small price to pay for the reduction of soot.
Mike
Old Jun 8, 2010 | 01:35 AM
LaxPlaya21's Avatar
LaxPlaya21
I am confused I though the stock exhaust was a 4" no? I also believed the inner diameter of the down pipe was 3.5" however, that thing was choked up! Cut through that thing a take a look at the crimped bends. Absolutely terrible! That is why I chopped it and am running a ceramic coated 4" dp. I think it flows a little better and spools up a touch quicker. I like it.
Old Jun 8, 2010 | 01:37 AM
LaxPlaya21's Avatar
LaxPlaya21
Also, I can't see what engine failure would have to do with the DPF delete.. the only thing the dpf coincides with is after market tuning, and if anything would cause a engine to blow would be hot tunes and a heavy foot!
Old Jun 8, 2010 | 08:14 PM
stevestroke01's Avatar
stevestroke01
I think the OP was trying to point out that there are probably going to be less failures tuned with DPF delete due to a lot less fuel in the oil problems from the regen.
Old Jun 8, 2010 | 08:53 PM
UGA33's Avatar
UGA33
Have a good buddy and an acquaintance that lost their motors and were tuned and ran hard. Both could be attributed to faulty injectors letting go and filling the crankcase with fuel causing run aways.
Old Jun 8, 2010 | 09:31 PM
gerbinator's Avatar
gerbinator
on u tube a guy has a dpf delete spartan programer and stock pipe still sounds great like it has a turbo dpf-r 4.0 is a dpf delete system without having to flash your system NO WARRANTEE PROBS just put the filter back in before dealership if engine probs under warrantee your clean gearbox z is where u can find
Old Jun 8, 2010 | 11:21 PM
LaxPlaya21's Avatar
LaxPlaya21
Thanks for the clarification, sometimes I am reading and responding at like 1am... and nothing every makes sense to me at that time. Hahahaa.
And, I haven't heard of many engine failures, tuned or not. Everyone I know that has a 6.4 is happy stock, but unhappy with mileage... or extremely happy tuned, and happy with the mileage!
I also have a friend with 1200 miles on his 6.7 and he is averaging 13-14mpg. Which is what I was getting on my 6.4. So maybe he still needs some break in time.
Old Jun 9, 2010 | 11:47 AM
  #28
gerbinator's Avatar
gerbinator
my truck is my daily driver and push snow comm in winter for a hospital some times 20hrs straight not good for re gen it wont happen so that why I went with dpf-r test pipe and tricks comp thinks still there in a way but doesnt flash computer not detectable 1hr back two stock for dealership
Old Jun 9, 2010 | 05:21 PM
  #29
capt caper's Avatar
capt caper
Did you ever check to see what kind of increase in mileage you get? I liked the priceing and product you linked us too. From what I read the only way to get the most mileage is with a 250 tune from Spartan.
Old Jun 9, 2010 | 07:51 PM
  #30
StanleyZ's Avatar
StanleyZ
You know I hadn't thought about that. Does anyone know what kind of mileage they get on those trucks. I guess the trucks are built with no DPF and a different tune on the computer.
