PCM issues?
Old May 29, 2010 | 04:52 PM
sportsdad's Avatar
sportsdad
Repaired the problem with the light and nothing. I still get codes. Erase them then restart and they come back. I'm still thinking PCM reflash, but it was worth a shot. Thanks for the help 1997F-350.
Old May 29, 2010 | 05:34 PM
1997F-350's Avatar
1997F-350
you've been chasing this code for months?????
0380 GP Glow plug ckt malfunction Glow Plug Relay - KOEO OCC test Open/grounded ckt, solenoid open/shorted, failed PCM
if so i would think the last two words of that code....or maybe your VSS. have you replaced that yet? isnt there some sensors on the side of the tranny as well?
i dont see how this would affect your tranny unless it was the pcm part in that case i dont think a reflash is going to help ya. assuming your truck has been starting over the last couple winter months ok?
sorry i dont know a thing about auto tranny's. i've never owned an auto anything except this current piece of dura i drive now.
have you tried disconnecting the batteries with the headlight switch on to reset pcm? is your truck chipped?
Old May 29, 2010 | 05:45 PM
1997F-350's Avatar
1997F-350
i cant remember the name of the place....they sell the aftermarket tranny with a purple torque converter and "BUILD" powerstroke tranny's..maybe a call into him might point you in the right direction. sorry i cant help more.
Old May 30, 2010 | 11:28 AM
sportsdad's Avatar
sportsdad
I've checked the VSS and it seems ok. The speedometer has never acted up so I think I'm good on the VSS. There is another sensor on the trans, but I can't remember what it is. My buddy with the trans shop has done a few rebuilds for me (good ones) and he says the multiple trans codes sounds like what happens when the harness to the trans is disconnected, but that never happened. He thinks it might be the PCM.
I've simply been trying to keep this thing in great shape and get it sold without spending gobs of $$$ on it. Looks like I should head to the stealership. Hate to do that.
Old Jun 4, 2010 | 12:25 PM
sportsdad's Avatar
sportsdad
***UPDATE***
New news on my PCM/GPR/P0380 issue. While tinkering around in there, I had my son turn the key on. My arm was laying on the GPR. It cycled on as usual and then got red hot quick. Burned the $#&% out of my arm. This is either the first time this has happened or the first time I noticed it. Do you think this might point to a short under the valve cover. It was mentioned early on when first started in on this project. I guess I'll go ohm checking again.
Old Jun 4, 2010 | 08:10 PM
1997F-350's Avatar
1997F-350
as has happened in my(dad) case the ipr wiring and fuel bowl burnt the pcm.....you may or may not have this problem but all those wires down there are interconnected. go digging i guess. hopefully you dont have the same problem i do. have you replaced the Gpr? i do not endorse the CHEAPO napa 109 any longer. in your case it may work for the short term though
Old Jun 4, 2010 | 08:25 PM
Action4478's Avatar
Action4478
Hot GPR is normal... Have you looked ate the fuses,Relays ?..
WHEN i accidentally shorted my IPR, I ruined my IDM ...
Old Jun 6, 2010 | 07:38 PM
myoldblue97444's Avatar
myoldblue97444
Hey guys sorry to but in but, I'm having some of the same issues! My OD keeps going on and off and no one can pull codes and my triball was blown. LOVE to know direction to head in!!!
cruzer17
Jul 6, 2017 06:20 PM
Jmudweiser
Sep 13, 2016 05:02 PM
rwdfan
WTB - Ford Trucks & other vehicles
Feb 2, 2012 02:36 PM
Krazymaan
Aug 24, 2011 06:53 AM
Visseroth
39
Jul 27, 2009 06:25 PM
