PCM issues?
Old May 27, 2010 | 03:00 PM
sportsdad's Avatar
sportsdad
PCM issues?
I think I need to have the PCM in my 97 F250 (cal) flashed. What is the process and what should it cost? Can I just take the PCM or will they need the whole animal?
Old May 27, 2010 | 03:55 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
You can just take the PCM to a Ford dealer for a reflash.
Old May 27, 2010 | 05:35 PM
1997F-350's Avatar
1997F-350
why do you say this?
Old May 27, 2010 | 05:36 PM
sportsdad's Avatar
sportsdad
Thanks claetus. Anyone else?
Old May 27, 2010 | 05:38 PM
1997F-350's Avatar
1997F-350
why?????? do you think you need a reflash
Old May 27, 2010 | 05:45 PM
sportsdad's Avatar
sportsdad
Assuming you're asking me, I've been chasing a P0380 code for months. I've also developed some trans codes. I've run the entire electical system and it all checks out. I took it to the shop that rebuilt the trans, they say it's in good shape and they think it's the PCM. I discovered that the "reputable" shop that put a new GPR in the truck a couple of years ago, put in a starter relay that is known to do bad things to PCMs (so I've been told). Truth is I'm stumped and don't know what else to do.
Old May 27, 2010 | 05:58 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Well in that case, I think you may be chasing your tail. I think you need to have it diagnosed by someone who knows what's going on.
Old May 27, 2010 | 11:30 PM
1997F-350's Avatar
1997F-350
i assume the truck is acting up other than just throwing a code? i did not look up your code.....you say the electrical system checks out huh? is your 3rd brake light blown?
check this thread out: https://www.ford-trucks.com/forums/9...eep-dying.html
Old May 28, 2010 | 08:02 AM
sportsdad's Avatar
sportsdad
I actually read that thread yesterday, but I have not had time to check out the truck yet.
Yes it's acting up with different symptoms in the transmission coming and going. Sometimes the TC locks up at idle. Sometimes it holds in a gear and will not shift. These are always intermitant and change often. Sometimes, as it did yesterday on the way back to the ranch from my buddy's shop, it runs like a bat outta hell perfect. NO CODES. Pull in the shop, kill it, restart, codes? The P0380 never goes away for long. Sometimes comes back while driving.
I'll check the light and report back.
Old May 28, 2010 | 09:57 AM
1997F-350's Avatar
1997F-350
i'm not an auto guy at all. but now that you have posted up some more info hopefully someone with some insight on a sensor or something will chime in. the 3rd brake light is an option as well.
Old May 28, 2010 | 08:47 PM
1997F-350's Avatar
1997F-350
did you find out anything today?
Old May 29, 2010 | 09:25 AM
sportsdad's Avatar
sportsdad
As it turns out, the third brake light was out. I didn't have time yesterday to do anything so I asked my mechanic to check it out. I'm headed out there soon to check the results myself. I'll let ya'll know soon.
Old May 29, 2010 | 09:53 AM
1997F-350's Avatar
1997F-350
Old May 29, 2010 | 10:06 AM
sportsdad's Avatar
sportsdad
I hope I save BIG $$$$$$$$$
Old May 29, 2010 | 03:40 PM
1997F-350's Avatar
1997F-350
i meant thats money if that was the problem. well hope it works out for ya let me know im curious
