shifting
Old May 26, 2010 | 03:34 PM
1993f-250's Avatar
1993f-250
Exclamation shifting
i just rebuilt my automatic 93 f250 460ci and it shifts at 4 grand. only 4 grand. it doesnt kick down or anything and i swear i still havnt had it shift into 4th gear because 4 grand in 3rd gear is around 85 in my truck. how can i adjust this?
Old May 26, 2010 | 05:20 PM
jplinville's Avatar
jplinville
Has it kicked any codes?
Old May 26, 2010 | 06:22 PM
danr1's Avatar
danr1
Yea check for codes would be my first suggestion as well, that and do a quick check make sure you plugged everything back in.
The solenoid pack (Passenger side) and MLPS (Drivers side) connectors both? Both good solid connections (fully locked on) and added dielectric grease to them?
Old May 26, 2010 | 06:58 PM
1993f-250's Avatar
1993f-250
i just realized i may have made it sound like i re-built the tranny. tranny is stock. engine is re-built. ha sorry if thats how it sounded.
no codes.
and im almost positive all the electric connections are in good and all hooked up.
what does MLPS stand for? and where exactly is that solenoid? i do have a gold colored solenoid looking thing that i thought was attached to the vaccum lines..
Old May 26, 2010 | 07:06 PM
danr1's Avatar
danr1
'93? You have a C6 transmission, not a E4OD?
If its a c6 (three speed without overdrive) then you have a shift modulator, the "gold colored solenoid looking thing" and that should have a vac line and it should be connected directly to the intake manifold for full engine vacuum.
But you stated you didn't think it shifted to fourth?
AOD-E?
Old May 26, 2010 | 08:59 PM
1993f-250's Avatar
1993f-250
i was told it should have a 4th gear and even though when i 1st got it i didnt pay much attention i thought it shifted a 3rd time. i def seem to be running higher rpm at around 70 75 than i was before i re-built the engine. and it doesnt kick into the next gear until it hits 4k which is bothersome because then it holds at 3-3.5 thousand rpm at the speeds i use more commonly. it used to kick down.
Old May 26, 2010 | 09:18 PM
danr1's Avatar
danr1
Really need to know what trans you have to give the correct advice.
Have a O/D on off button on the end of the shifter?
The door jamb sticker lists a trans code, providing no one swapped in another model at some point in its life.
Should be a E4OD I'd think....
Old May 26, 2010 | 09:31 PM
1993f-250's Avatar
1993f-250
no trans swap that i know of and i dont have o/d
Old May 26, 2010 | 09:41 PM
1993f-250's Avatar
1993f-250
door jam says "G" for trani. Chart says that means C6 auto
Old May 26, 2010 | 09:47 PM
danr1's Avatar
danr1
Ok then check that vac line to the trans, you probably just missed it when working on the engine.
Its a short section of rubber down at the trans pan, changes to metal tubing up the trans to the back of the intake, then changes back to rubber again. At least it would have been that way stock, someone may have ran rubber all the way. That's fine just make sure its away from the exhaust and no leaks.
Old May 26, 2010 | 09:54 PM
1993f-250's Avatar
1993f-250
thanks alot. il check, everytime i shut off my truck i hear a hissing sound from a vaccum leak behind my uppr plenum sumwhere. that might be it. thanks.
lemasters f100
1983 - 2012 Ranger & B-Series
Sep 27, 2014 09:29 AM
scbronco
Sep 19, 2008 05:43 PM
roofmower
Aug 7, 2004 08:51 PM
Skipdaddie
20
Dec 13, 2002 03:28 AM
