Weird ac problem
Old May 25, 2010 | 09:04 PM
chicagodragon's Avatar
chicagodragon
are you connected to the canister by the firewall? if so, that is the accumalator/low side. reading 100ish psi means the system is not kicking in, make sure the clutch is pulling in. is this reading with the engine on or off?
Old May 25, 2010 | 10:11 PM
RubberDuck's Avatar
RubberDuck
Glenn nailed it. The electrical connection on top of the compressor is a high fail connector. Wiggle it with the a/c on max. If it engages the compressor, that's your problem. I've seen it 100 times. That connection needs to be cleaned, or modified. If you can't clean it, holler at me and I'll explain the mod so to speak.
Old May 25, 2010 | 11:45 PM
oldbird1965's Avatar
oldbird1965
I'm hollering, in case mine stops again. I try my darnest not to lay on it when I'm working on the motor but you know how that goes, LOL!
Old May 26, 2010 | 03:34 AM
RubberDuck's Avatar
RubberDuck
I find that you can't really clean that plug too well. So I remove the red lock that holds the female pins in place. Take about a 3/4" long piece of thin stranded wire. strip it and separate the strands. bend 4 or 6 of them in half. Put half a leg of a strand in the female connector, and the other leg let it hang where the lock rides. You may need 2 or 3 strands per pin. When you push the lock back in, it will lock those strands in each female socket. The strands will take up the slack, and make the connection better. Does that make sense?
Old May 26, 2010 | 09:25 AM
Neal 97 250's Avatar
Neal 97 250
Glenn and Cody are correct. I had the same problem except mine would work for a bit then quit. Back and forth till it finally quit cooling.
Thanks to Cody I cleaned the plug reassembled it a voila' it works great and has ever since.
Thanks again Cody
edit: Reps sent Cody just because I could.
Old May 26, 2010 | 09:52 PM
oldbird1965
HEY, where's mine Neal? Just kidding, I meant to point out the fact that when the clutch was engaged mine blew REALLY cold air so I assumed the system was full. Going down the road on a hot day you defiantly knew when it quit. When pulling a load its tough to find a spot to pull over it get it working again. I'm even is the habit of checking the clutch engagement activity after laying on it to work on the engine! Good Mod Cody!! I'll try some beans.
Old May 27, 2010 | 07:08 AM
Neal 97 250
OK there you go. Beans to you too. LOL
I hope this works for you.
tommy curtiss
Aug 9, 2016 04:30 PM
lawdawg79
Jul 25, 2015 09:39 PM
Ford12006
2004 - 2008 F150
May 27, 2014 10:18 AM
hotrodhippi
Dec 6, 2013 02:46 PM
tidexp
22
Jul 2, 2012 08:30 PM
