1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Do I need a superduty?
Old 05-25-2010, 01:14 PM
schaibaa's Avatar
schaibaa
schaibaa is offline
Hi guys,
I have an 8.5 x 20 enclosed trailer. I do sound/light/staging production - and currently it weighs in at 6500lbs. Soon it will get to be more like 9k. It's a dual 5200lb axle.
Is this F150 territory or do I need a superduty? I do this 2 times per month on average - usually short trips (30 miles each way) and a couple times per year I go 100 miles each way.
Thanks!
Old 05-25-2010, 01:32 PM
BLK94F150's Avatar
BLK94F150
BLK94F150 is offline
I'd say you're on the fence depending on what year F150. If it were me, I'd go for the SD.
Mike
Old 05-25-2010, 01:53 PM
Elvis40's Avatar
Elvis40
Elvis40 is offline
personally i would rather be over trucked, than under trucked.
9k is quite a bit. I think you would be much happier with the SD when you are pulling.
Old 05-25-2010, 02:35 PM
senix's Avatar
senix
senix is offline
Received 1,553 Likes on 1,107 Posts
I would go with a F250 with a gas motor, that way you have room to grow.
Old 05-25-2010, 02:43 PM
phillips91's Avatar
phillips91
phillips91 is offline
I would vote for a SD gasser as well. The v10 would be the best route to go, but a 5.4 or 6.2 will still get the job done with no problems too.
Old 05-25-2010, 03:01 PM
gearloose1's Avatar
gearloose1
gearloose1 is offline
At least a 350SD, preferably a 450 if you are that loaded 24/7/365.
Old 05-25-2010, 05:15 PM
BLK94F150's Avatar
BLK94F150
Why? It's within the capacity of an 04+ F150. He already said it's just a couple of times per month. Regardless, a 350 is overkill and a 450 is rediculous. 250 SRW will be more than enough. Diesel, gas, whatever, it doesn't matter.
Mike
Old 05-25-2010, 05:44 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
I believe this is firmly within newer F150 capabilities, so not sure I would go as far as to say "need".
But... If you need to climb steep grades or pull at high altitudes, definitely lean towards SD V10 or diesel.
Another factor: Fuel economy concerns? If yes, F150 all the way.
Old 05-25-2010, 05:59 PM
LSchicago2's Avatar
LSchicago2
LSchicago2 is offline
Go for the Super Duty. Any 250 or 350 should work. V10 or 6.2 if gas. Stay away from the 6.0 if diesel.
Old 05-25-2010, 06:17 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
yup as stated above many times..
go SD. better to have to much truck with room to upgrade trailers then buying a F150 and being maxed out or to close to it.
Old 05-25-2010, 07:04 PM
gearloose1's Avatar
gearloose1
I always derate manufacturers claims of towing capacity by 20 to 30% depending on how aggressive they are.
If fuel economy is a factor, time to lighten the load.
Old 05-25-2010, 09:00 PM
BLK94F150's Avatar
BLK94F150
None the less, F250 is plenty.
Mike
Old 05-25-2010, 09:27 PM
luverofpeanuts's Avatar
luverofpeanuts
luverofpeanuts is offline
Originally Posted by schaibaa
Hi guys,
Thanks!
With the information so far, I'd say, you're on the fence. Do you want/need a crew cab? If yes, then no question... you have to go SD in my mind. The half ton crew cabs don't have enough payload to have a loaded crew cab and truck bed...in addition to pulling a trailer like that.
If you don't need a crew cab...and can go regular cab, or just super cab. Then I think an F150 with the HD payload would be pretty attractive.
Just my 2 cents ;-)
Old 05-25-2010, 09:55 PM
5.4f250sd's Avatar
5.4f250sd
5.4f250sd is offline
I am going to say no! You don't NEED a superduty. I know a guy that pulls 6000lbs with a mini van on trips that are 220 miles, and he has been doing it for 250,000 miles with multiple brands. I don't condone this type of behavior, that is not what I am saying. A properly setup 150 will pull that without a problem. It just depends if you want a superduty body style or not. I like the idea of over kill but it is not necessarily. So go out and drive one and see if you like it and let that be the judge not your trailer.
Old 05-26-2010, 07:07 AM
redford's Avatar
redford
redford is offline
Received 1,631 Likes on 955 Posts
Yes, you do NEED a Super Duty.
While an F-150 can be equipped to handle the trailer you tow, a Super Duty will tow it much better. Having a heavier truck under you, with better brakes and better suspension, makes all the difference when you get into bad weather, high winds, tour buses blowing past you at 80 MPH and stuff like that.
A 2005+ truck with a 5,4L engine and 5R110W transmission will handle the load just fine. Find one with 4.10 gears if you tow in mountain areas. My truck (see sig) regularly tows a 28 foot enclosed car hauler (around 8000 pounds) without any issues.
Quick Reply: Do I need a superduty?
