before i go to far
Old May 29, 2010 | 09:46 PM
johnboggs21's Avatar
johnboggs21
Originally Posted by 92f2504x46.9
got all the fuel leaks fixed , greased what i could underneath cleaned the engine a bit more, turned up the ip , need to work on window motors , adjust clutch , get keys made for doors,and ?
careful turning up the IP. Get it to hot and you can melt holes in the pistons. I suggest installing a pyrometer to keep an eye on the EGTs. Things start to go sour around 1250*f
Old May 29, 2010 | 10:13 PM
92f2504x46.9's Avatar
92f2504x46.9
I will get a pyrometer , I only turned about 1/8 turn , but didnt seem to notice any change , was wondering if i turned it the wrong way ? so need to weld in a bung hole for pyro ? should i do one on both sides ?
Old May 29, 2010 | 10:17 PM
johnboggs21
nah only need your thermocouple on one side. You probly wont notice 1/8 of a turn. Mines turned up about 1 flat which is 1/6 of a turn. If you turn it in thats turning it up, turning it out turns it down. Standard right hand threads.
Old May 29, 2010 | 10:22 PM
92f2504x46.9
oh ok , so tell me about this thermocouple . i will turn it up i bit more , oh do you know how to adjust hydro clutch ?
Old May 29, 2010 | 10:29 PM
johnboggs21
im an auto guy (not by choice either lol) so im no help on clutches. The thermocouple gets hot and generates electric to move your gauge. At least thats how I understand it to be.
Old May 30, 2010 | 12:17 AM
92f2504x46.9
was just wondering if the coupler is a strap on type thing or does the exhuast have to be modded ?
Old May 30, 2010 | 02:07 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Most drill and tap a hole in the exhaust manifold collector on the drivers side for the pyro ... #8 supposedly gets the hottest.
There is no adjusting hydraulic clutches, thats one of the points of them.
-Enjoy
fh : )_~
Old May 30, 2010 | 07:16 AM
luthrobediesel's Avatar
luthrobediesel
Some ford trucks have threaded rods on the master cylinder with a locknut. You take it loose from the clutch arm and turn it out for more free play.
Old May 31, 2010 | 04:05 PM
92f2504x46.9
yup that worked great
Ziggy81
Nov 20, 2013 06:41 PM
86sixbanger
May 13, 2012 01:59 PM
bad12jr
34
Feb 6, 2012 04:56 AM
artfd
Jan 1, 2012 08:13 PM
ddb
Oct 23, 2005 11:31 PM
