Do you balance your Wicked Wheels?
Do you guys think it is necessary to balance the turbo shaft after installing a Wicked Wheel? From what I have heard on other forums most people do not balance the shaft after installing them and have had no problems. Has anyone here had a problem with their turbo becasue they didn't have it balanced after installing a WW?
the wicked wheel i bought was balanced already. it has wheel paint on it. if your rotating assembly is within spec now, then adding a balanced wheel shouldn't affect it. i did learn one thing, do not reach in and spin the wheel with your finger. the oil and "stuff" on the wheel accumulates on there in perfect balance. when you move it with your finger, it wipes off the oil and other stuff that is on there. this then causes a small inbalance. this causes a very mild vibration in the turbo shaft. it doesn't seem like alot, but at 150,000+ RPM, it can be very serious. if you want to spin the wheel, grasp the center part with the 5/8" socket (i believe) end.
Nut
Originally Posted by cookie88
Not so high as you might think. Completely stock it will spin 100,000+...and that's at 15-17 psi. Add enough drive pressure to kick it up to 30 psi.........
At any rate, it's spinning really, really fast.
friday i learned that one some of the new ACERT Cat engines, during testing that they have measured up to 280,000 RPM out of a VGT turbo that has had the vanes stuck in the closed position. it didn't come apart. most OTR diesels run their turbos around 160,000 RPM at full boost which is about 30-45 psi. stock powerstrokes run around 130,000 RPM.
Originally Posted by Kwikkordead
I don't know if one could even hear the whistle at 280 grand. It would drive every dog insane though!
01f350 - most people have no trouble with a WW that hasn't been balanced. I had this discussion through email with Jody Tipton and a couple of other people. The general consensus was that 1) though the wheel is sold balanced, the original compressor wheel and shaft were balanced together, so adding a perfectly balanced WW may still cause vibration and early bearing failure; and, 2) the best way to fix turbo surge (short of a new turbo) is the ATS ported compressor shroud.
It has a few upsides:
You don't need to remove the turbo to replace the housing.
It uses the stock compressor wheel - no balancing needed.
It reduces surge more than a WW.
It flows more air than a WW in a stock housing.
It has a few downsides:
Price.
It uses the stock compressor wheel. If you like the sound of the WW (and who doesn't?), then, sorry - it works best with the stock compressor wheel, so it doesn't sound as good.
I have one - it is sitting in my garage awaiting installation. BUT - I need to do my taxes and a bunch of other things first. Then, I'll do some fun work to the truck.
Price.
oh about $3000....what? ....oh look i found this SALE on a BB turbo for only
$1600....oh good buy it!
