Transfer case problems
Old May 24, 2010 | 08:17 PM
34dawg's Avatar
34dawg
I just bought a 1986 Ford F350 4x4 and can not get the transfer case into low range at all, its a BW but don't know which one. It will go into high only.
Old May 24, 2010 | 08:23 PM
86fn150's Avatar
86fn150
my 86/5.8/c6 has a bw1345 but not sure what yours has.supposedly you are to put trans in (n) and shift to 4lo.but with mine it's better to have truck shut off and pull lever straight to 4lo in one motion.if i go slow it may take a few times.
Old May 24, 2010 | 09:51 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
My '86, BW1345, push in the clutch, stop and pull it in, goes right in, never had a problem.
You might check the simple linkage.
You don't say auto/manual.
Either way, try using the motor to turn the trans/TC a little (gently) as your trying to shift, does the shifter just stop or does the TC grind?
-Enjoy
fh : )_~
Old May 24, 2010 | 10:07 PM
bghnkinf250's Avatar
bghnkinf250
Mine has a 208. Apples and oranges, but I had the same problem. It turns out the arm on the transfer case was flipped the wrong way. If it will not go in with the engine off, try disconnecting the linkage and shift it by hand under the truck to see if it goes through the ranges.
Old May 25, 2010 | 08:10 PM
34dawg's Avatar
34dawg
I finally got it to go into low range, I had to take the shifter boot off the floor pan because it was in the way when I pulled it back. The truck is lifted up pretty high and the shifter was modified. I just have to rig a new boot for it. Thanks for all the help.
smittys5xs
1978 - 1996 Big Bronco
Apr 22, 2015 09:44 AM
Andy Sullivan
Feb 15, 2014 04:52 PM
SoArkSI
Nov 5, 2005 08:43 PM
