Mod questions
Old May 24, 2010 | 07:03 PM
Chris68GT's Avatar
Chris68GT
Mod questions
I've heard talk of a few mods that sound interesting but am unclear on how to execute or the benefit of them. The first one is swapping out 6 cylinder air-box for your v-8. Any info or tips on this would be great. Also I've heard talk of making my 'dummy' oil pressure gauge into a 'real' one, is this possible? Also, I plan on a rebuild soon with a new cam and some headers but any other 'easy' horsepower/torque mod suggestions are welcome! Thanks!
My truck is a '91 F-150 with a 5.8 and an E4OD with the AIR injection removed, other than that, it's basically stock right now.
Old May 25, 2010 | 04:36 PM
Chris68GT's Avatar
Chris68GT
Bump, bump.
Old May 25, 2010 | 05:14 PM
cjben's Avatar
cjben
the air box swap is plug and play.take the v8 one out,put the 6 cyl one in,no modification needed.
Old May 25, 2010 | 05:18 PM
andym's Avatar
andym
Don't expect it to make any difference at all.
Old May 25, 2010 | 06:52 PM
Big Blue II's Avatar
Big Blue II
I have been told the Oil pressure gauge on the Fords is able to read pressure just use a sending unit from an older truck, say 1985 with a manual gauge. Cheap and worth a try.
Old May 26, 2010 | 04:29 AM
TexasGuy001's Avatar
TexasGuy001
It does make a difference especailly when its hot weather with the AC on on while driving on the highway. I can tell the mine is running better.
My friend, did the same to his 96 truck and he agrees with me.
This is the I6 tube.
Old May 26, 2010 | 04:37 AM
TexasGuy001
Deosn't 87-91 already pull air from this location on the 5.0 and 5.8 trucks?
khadma's Avatar
khadma
Carpenter Local 745
My friend Jason, did the same to his truck and he agrees with me.
[img]https://www.ford-trucks.com/user_gallery/sizeimage.php?
&photoid=218680&.jpg[/img]
I was planning to build a custom intake out of carbon fiber for my FSB, but until then do you have a source for more I6 intakes? I need one for now.
I am doing many mods/upgrades to my FSB.
Here is the thread.
I also will be installing a new electric oil pressure gauge. I just have to buy my stainless hose and fittings.
https://www.ford-trucks.com/forums/9...e-build-2.html
Old May 26, 2010 | 04:43 AM
TexasGuy001
The only places I know that you can get one are Ebay which sometimes has them. Sometimes its hard to find one because not every seller knows how to list it so you have to search all types word combinations. The other place is a salvage yard.
Old May 26, 2010 | 07:34 AM
96ford250's Avatar
96ford250
salvage yard is by far the best place i got mine for 5 bucks at a pull it yourself there all over the place down here in NC. I6 f150s are everywhere in the salvage yards.
Old May 26, 2010 | 09:30 AM
zxwut?'s Avatar
zxwut?
You can use a 460 tube also.
Old May 26, 2010 | 02:27 PM
Conanski's Avatar
Conanski
No it goes over top of the rad.
Old May 26, 2010 | 02:44 PM
Eddiec1564's Avatar
Eddiec1564
There is a oil pressure guage modification you can do the make your" idiot" gauge work like it should. On the back side of your instrument cluster inline with the oil gauge there is a 20ohm resistor. Just jumper it out(short it) and replace your sending unit with one from a 87 or older truck. I have done this mod to my 89 F250,89 Bronco2 and 95 E350. Works every time, but the factory guage is not as accurate as a real one, but better than the "idiot" guage! At least I now see the guage moving lower at idle with engine warm. The "idiot" guage would show mid ways as long as the oil pressure was over 7psi or so.
Old May 26, 2010 | 02:50 PM
khadma's Avatar
khadma
Carpenter Local 745
It is hard to find used truck parts in my location. Local recyclers move their "inventory" quickly.
Old May 27, 2010 | 02:04 AM
TexasGuy001
Thanks, I couldn't remember.
