EBPV Plug for rod.
Old May 24, 2010 | 06:39 PM
Talyn's Avatar
Talyn
EBPV Plug for rod.
Anyone have any instructions on the EBPV delete?
I dont wanna have the wrong crap welded up and be in a hurtin for a new pedestal.
A good way to cut off that housing as well would be another good tip I could use. I'm limited on tools. I guess I could use a grinder with a cutoff wheel. Might get to hot though. =\
Old May 24, 2010 | 06:41 PM
Talyn's Avatar
Talyn
Oh, the valve that actuates the hydraulics for the EBPV was what was leaking on me. I'm pretty sure thats what was it. I wouldn't be surprised if the EBPV cylinder was leaking either.
I was looking at it, the seal for the end of the rod isn't the greatest, where people usually plug it up. Good spot for it to leak. I'm sure it was leaking there too. I just didn't see any signs of it.
Old May 24, 2010 | 06:48 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Maybe this helps you:
https://www.ford-trucks.com/forums/8...-write-up.html
Here are diff. pics.
http://photos.thedieselstop.com/show...34/ppuser/5220
https://subs.webshots.com/regsub?vho...28475244HYBUKV
Old May 24, 2010 | 06:57 PM
Talyn's Avatar
Talyn
Modded Pedistal pictures from outdoors photos on webshots
here is tims pic
I"m just not sure how to weld the actuator hole, to plug it at the top, or to fill it in.
Old May 24, 2010 | 07:02 PM
Talyn's Avatar
Talyn
thanks Jose.
Those pics and links are awesome. The one doesnt work though.
Old May 24, 2010 | 07:06 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
thanks Jose.
Oh, it works for me, try again because I think is the best (write up)
Old May 24, 2010 | 07:07 PM
427 fordman's Avatar
427 fordman
https://www.ford-trucks.com/forums/9...d-removal.html
I found the link for help I had, if it works. I followed gobstoppers writeup
Old May 24, 2010 | 07:08 PM
Talyn's Avatar
Talyn
That one works, the webshots one didnt.
I messaged Gobbstopper though.
The thing I'm worried bout most is welding the actuator hole up.
I dont think i'm going to go as overkill as he did. I dont have the money to pay for the welding.
And I dont have the aluminum pipe. haha.
Old May 24, 2010 | 07:14 PM
Action4478's Avatar
Action4478
From memory ,I think a 29mm freeze plug works to fill the hole...
Old May 24, 2010 | 07:17 PM
427 fordman
I didn't have the pipe either but the shop I took it to did. I just wanted to follow his writeup completely cause it turned out so good. Good luck with it.
Old May 24, 2010 | 07:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Old May 25, 2010 | 07:22 AM
Talyn's Avatar
Talyn
Wrong county there rick. haha. =)
I got the EBPV deleted a few months ago.
Old May 25, 2010 | 08:16 AM
Neal 97 250's Avatar
Neal 97 250
Huh???????
Old May 25, 2010 | 08:50 AM
Talyn's Avatar
Talyn
Working on the pedestal bro. Pedestal.
Old May 25, 2010 | 08:51 AM
Talyn's Avatar
Talyn
I guess I was a little vague about it. DOH!
