Rear axle
Old Feb 3, 2003 | 10:30 AM
drukakoski's Avatar
drukakoski
Rear axle
Will a rear end from a 1987 to 1996 truck fit my 1986 Ford F250? I currently have a worn out 10.25" semi-floating rear end, and would like to put in a newer 10.25" full floater.
Any info would be apprecieted.
Thanks,
Dan-O
Old Feb 3, 2003 | 04:36 PM
Franklin2's Avatar
Franklin2
Rear axle
Not knowing anything about those rears, I did a little test that you may want to try. I went to
www.car-part.com
and plugged in your truck. It gave me 1986 and 1985 choices.
I then plugged in your style truck as an 1987. it gave me choices from 1988 on up to 1997. So reading between the lines no. Can it be made to fit? Maybe. But it will not be a direct replacement according to the junkyard list.
Old Feb 4, 2003 | 10:16 PM
steve83's Avatar
steve83
Rear axle
Yes, it'll fit fine. The only difference is the ABS sensor, which won't matter putting it into an older truck. You just can't put an old axle in a new truck, or the ABS won't work.
nmclea02
Jan 27, 2011 12:33 PM
SuperSnake
Oct 9, 2010 05:28 PM
MychalCrowson
Mar 23, 2007 12:17 AM
orange78oval
1978 - 1996 Big Bronco
Feb 1, 2004 02:09 PM
orange78oval
Jan 25, 2004 08:11 AM
