rear end question
Old Jan 27, 2011 | 12:22 PM
nmclea02's Avatar
nmclea02
rear end question
Will a 1995 sterling 10.25 rearend bolt right into 88?
Old Jan 27, 2011 | 12:24 PM
joe f350's Avatar
joe f350
it should if they both came obs truck
Old Jan 27, 2011 | 12:33 PM
greywynd's Avatar
greywynd
Make sure they are both pickups, and one isn't a cab and chassis (different axle/frame widths.) The sensor on the '95 is used for the ABS and the speedo, not sure if it is the same sensor as what is used on the'91 and earlier trucks or not, so that may require switching.
Watch the gearing too, make sure it is what you are looking for, and if it's going into a 4wd truck that it matches the front.
Some checking with a tape measure will confirm though, basically the width of the spring perches, and backing plate to backing plate widths are the critical ones you need to confirm.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
