need help
Old May 23, 2010 | 11:50 PM
sechols's Avatar
sechols
need help
i was pulling a 16 foot horse trailer to day. and started up a hill and the truck lost all boost and all power and was blowing a dark grey smoke. it did it once before but i killed the truck and waited 10 min and it was fine now it's not
Old May 24, 2010 | 04:55 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE
A little information is helpful, model year, modifications if any and the ability to at least read codes if you can.
Old May 24, 2010 | 06:40 AM
craftsmangary's Avatar
craftsmangary
Any codes? You need to get it scanned and go from there.
Old May 24, 2010 | 05:34 PM
sechols's Avatar
sechols
sorry it is a 06 f-350 king ranch no mods
Old May 24, 2010 | 05:47 PM
toolman05kr's Avatar
toolman05kr
With the limited info provided, My best guess would be the EGR valve hanging up. If it's still under warrentee bring it in ,If not , try cleaning it or if it's that bad, replace it.
Old May 24, 2010 | 05:49 PM
william_04_x's Avatar
william_04_x
check to make sure the blue boots on your turbo and intercooler are in good shape. the one on the turbo to CAC tube is prone to blowing off or tearing.
Old May 25, 2010 | 06:19 PM
sechols's Avatar
sechols
i changed the fuel filters and they had a gas in them like(unleaded) so i drained the tank and put fresh deisel in the tank and it started to run fine after the fuel in the lines went throught. i had the codes ran to day and it had exhaust gas recirculant low& egr position sensor minimum stop proformance and is runing fine now i cleared codes. would have n unleaded fuel in the truck cause those codes to come up. i just got the truck a few weeks a go it is my first deisel.
Old May 25, 2010 | 07:20 PM
06silvercrew's Avatar
06silvercrew
Pull the EGR valve and have a look at its condition. Pretty sure there is a good procedure for doing this in the folder at the top of the page. Its a simple task that just about anyone can do. If you changed your own fuel filters you can handle this job.
Old May 25, 2010 | 07:22 PM
06silvercrew
Here check this out. This is straight from the tech folder.
https://www.ford-trucks.com/forums/4...egr-valve.html
Old May 25, 2010 | 07:24 PM
cheezit's Avatar
cheezit
see there are only really 2 things you cant put in a diesel tank. water and gas. they dont like either. not even 92.
running the truck on gas can and will cause injector damage. remember always always use the green handle.
Old May 29, 2010 | 05:03 PM
sechols's Avatar
sechols
thank guys for all the info i am very thank full!!!!!!
Old Jun 1, 2010 | 03:47 PM
cp101's Avatar
cp101
Boy, is this good advice!
Going uphill this weekend in a remote part of Vermont and BANG! . . . the loud bang is followed by a 95% loss of power and 0.0 on the boost guage. Roadside assist flatbedded the truck out. Just got a call from the dealer . . . . CAC tube blew off. That was it. A simple part completely disabled my truck and ruined my weekend. I'll be checking those CAC tube clamps from now on.
Old Jun 17, 2010 | 05:44 AM
sechols's Avatar
sechols
i cleaned the egr and replace the cac boot also it had some creaks the truck is runing great.
Old Jun 17, 2010 | 10:44 AM
rotun's Avatar
rotun
Reads ***** rules!
That same thing happened to me in a cabover Peterbuilt, on a hill, at a stop light....turns green, step on the go pedal, release the clutch and BOOM! Sounded like a Howitzer going off when the tube slapped the bottom of the cab. Luckily we knew what it was and had it fixed in 5 minutes after cleaning our shorts.
badbrains
New Member Introductions
Apr 4, 2013 03:17 PM
charle123
Sep 6, 2012 03:22 PM
JMM-MD
Transit Connect
Jan 17, 2011 10:29 PM
02GrayPowerStroke
Oct 13, 2009 04:15 PM
Ervie
Dec 8, 2007 09:02 AM
