Check engine/Codes
Old May 23, 2010 | 07:37 PM
twister2gt's Avatar
twister2gt
Check engine/Codes
42HEGO HO2s Sensor voltage high/ system rich
33 EGR fault not closing properly
My check engine came on today and i got the system okay on KOEO but i ran a KOER and got 42 and 33 My egr valve has no vaccum going to it anymore so that could be it but i was really wondering what could be causing 42 the happen this is on a 89 F250 351 C6
Old May 24, 2010 | 09:31 AM
rla2005's Avatar
rla2005
DTC 33 indicates the EGR opening is not detected. That would make sense, you state there is no vacuum going to it.
Not sure what is causing the DTC 42. How old is the HEGO? Have you pulled it out to inspect it?
Old May 24, 2010 | 05:40 PM
twister2gt's Avatar
twister2gt
What is the HEGO? where is it located at?
Old May 24, 2010 | 08:03 PM
rla2005's Avatar
rla2005
HEGO = Heated Exhaust Gas Oxygen Sensor "aka" O2 sensor. It's located in the exhaust pipe near the manifold.
Old May 24, 2010 | 09:23 PM
twister2gt's Avatar
twister2gt
I replaced that about a year ago.
Old May 25, 2010 | 07:12 AM
rla2005's Avatar
rla2005
Next questions: Does your truck use oil? If it does the oil can contaminate the O2 sensor. Pull the vacuum hose off the fuel pressure regulator, check it for signs of a ruptured diaphragm by smelling the end of the hose.
How old are the plugs, wires, cap/rotor? Have you pulled the plugs and checked for signs of misfiring/fouling?
Old May 25, 2010 | 08:11 AM
twister2gt's Avatar
twister2gt
it uses about a quart every 3000 miles, the plugs are new the wires are about a year old the truck runs pretty good most of the time but sometimes it will start idling rough then it will stop and run good after a couple minutes. The truck does not smoke
Old May 25, 2010 | 08:20 AM
rla2005's Avatar
rla2005
That answers the oil consumption question. That leaves the FPR check and pulling the plugs to look for signs of fouling/misfire. You might also consider checking what the fuel pressure is with and without the vacuum hose attached.
Old May 25, 2010 | 04:45 PM
twister2gt's Avatar
twister2gt
Isn't using a quart every 3000 miles normal for a truck of this year?
Old May 25, 2010 | 07:30 PM
rla2005's Avatar
rla2005
I should have been more clear in my statement "That answers the oil consumption question". That is darn good for any model year in my opinion.
Old May 25, 2010 | 09:15 PM
twister2gt's Avatar
twister2gt
Took the vac line off the FPR today and i could smell gas, not really strong but you could tell, think i might try a new PCV valve first since i think mine is making a buzzing noise
Dakota_Don
1997 - 2003 F150
Feb 5, 2012 02:50 AM
boggerted
Feb 11, 2010 01:44 PM
04heritage4.2
Computer Chips & Tuners
Mar 19, 2007 06:20 PM
brandon0011
1997 - 2003 F150
Feb 25, 2007 11:13 PM
MemOrex
28
Mar 15, 2005 02:36 PM
