rough idle
Old May 23, 2010 | 05:33 PM
rulydog's Avatar
rulydog
rough idle
any ideas why my 97 f350 is idling rough when coming to a stop? it stalls sometimes too! could it be something with the vaccum? brake booster?
Old May 23, 2010 | 05:45 PM
F350-6's Avatar
F350-6
Welcome to FTE. Any mods done to your truck? First thing to check is your engine oil. Is it full, not overdue for a change, and a diesel rated 15w-40?
How long has this been going on and was there any work done to it before it started happening? Does your check engine light come on when it idles rough? Try unplugging the ICP sensor while it's idling rough and see if it smooths out any.
Old May 23, 2010 | 05:49 PM
Action4478's Avatar
Action4478
Need to copy & paste this ...
Good post Chris...
Old May 23, 2010 | 07:45 PM
Brown Falcon's Avatar
Brown Falcon
Check your fuel pressure at idle also. Should be between 50psi and 80psi. If it's lower it could contribute to the problem.
Changed the CPS at all?
Old May 24, 2010 | 05:55 AM
48' fordster's Avatar
48' fordster
Just throwing it out there....could be injector O-rings. Look in your fuel bowl and see if there are any black particles in the fuel.
kenf1948
13
Sep 20, 2002 08:19 PM
dvlinnell
Apr 16, 2002 11:29 PM
otto
Jun 10, 2001 03:15 PM
matt davis
Feb 15, 2001 03:10 AM
Ultramagdan
1997 - 2003 F150
Feb 2, 2001 03:25 PM
