Offroad & 4x4
70's frame with 89 body?
Old May 27, 2010 | 01:53 PM
  #46
fatdan460's Avatar
fatdan460
i know about the explorers, but those axles won't fit under a fullsize, so i didn't mention them :flipoff:
Old May 27, 2010 | 04:46 PM
  #47
JereThei's Avatar
JereThei
would the disc brakes swap to the full size 8.8 from the explorer 8.8?
Old May 27, 2010 | 04:49 PM
  #48
fatdan460's Avatar
fatdan460
probably, and i also believe they work for a swap on the 9 inch as well
Old May 27, 2010 | 04:55 PM
  #49
fatdan460's Avatar
fatdan460
just read that the explorer disks only work with big bearing 9 inch rears.
Old May 28, 2010 | 04:23 AM
  #50
Bender99's Avatar
Bender99
Originally Posted by hav24wheel
****, I don't remember the difference anymore. But I also have the front cab mounts moved from the stock 78 location. So that prob has something to do with it.
Difference is the newer ones are narrower cause the newer frames are wider. You put them on the old frame and dont work. Too narrow. The newer one's only have 4 rivits into the side of the frame and 70's have 4 on the side and 2 on top of the frame rail.
ryan f150 4x4
1978 - 1996 Big Bronco
Jun 24, 2021 09:56 PM
Shawnboylk
Jan 2, 2017 03:58 PM
GreenFlareside
Sep 12, 2012 02:33 PM
Sparky04SD
Oct 7, 2011 04:20 PM
lvin4jc
Apr 12, 2011 04:06 PM
