Offroad & 4x4
70's frame with 89 body?
Old May 26, 2010 | 05:53 AM
  #31
hav24wheel's Avatar
hav24wheel
Originally Posted by Bender99
You need 70's front cab mounts, not newer one's, dave didn't mention he smoked a little crack.
If u used the 70s ones, and I used the 80 up ones, I'd have to say they both work. There is more than one way to skin a cat.
Old May 26, 2010 | 10:43 AM
  #32
Prozon's Avatar
Prozon
Are you frickin' chinese? Who skins cats?
Speaking of the mounts though, what exactly are the differences.. cause you both say they will both work. Are they the same looking?
Old May 26, 2010 | 10:50 AM
  #33
hav24wheel's Avatar
hav24wheel
****, I don't remember the difference anymore. But I also have the front cab mounts moved from the stock 78 location. So that prob has something to do with it.
Old May 26, 2010 | 07:10 PM
  #34
JereThei's Avatar
JereThei
ok. i had a thought. would a d44 work for my application if i ran chromolly axles? it might be easier for me to get ahold of than a d-60. Also would 4:10 gears fit in the stock 79 carrier? It should be plenty of strength for 35's Although i would gusset the pumpkin to the tube just for my piece of mind.
Old May 26, 2010 | 09:53 PM
  #35
fatdan460's Avatar
fatdan460
a dana 44 with chromo shafts would probably suit most peoples needs. i know some people will see this and act like that was an insane statement, but chromo shafts and some superjoints paired with a little common sense on how to use the skinny pedal will keep that axle with 35's alive for a long time. 4.10's won't work on the factory diff unless you happen to have 3.92 or numarically higher gears from the factory. jeff's bronco graveyard sells trac-locks and open carriers in both high gear and low gear split, or buy an aftermarket diff for the correct gearset you plan to use. do you know the difference between high and low pinion?
Old May 27, 2010 | 01:00 AM
  #36
Prozon's Avatar
Prozon
I don't see you breaking the tube at all.. ever..
I've only seen it happen a few times:
Jumping it.
REALLY big tires, hitting mud fast.
I think your in the clear with 35's. And I HIGHLY doubt you will need chromo axles in the D44 either. It should hold up to 35's without any problems at all.
Old May 27, 2010 | 10:22 AM
  #37
JereThei's Avatar
JereThei
yes i do know the difference hp d44 came in 78-79 f-150s and broncos. thats the one im lookin to put gears in what would i have to specifically get for 4:10 gears just a whole housing or third member. i know how to set the gears in a diff. just not too sure on clearance. the high gearset im guessing is for the high pinion 44?
Old May 27, 2010 | 10:26 AM
  #38
fatdan460's Avatar
fatdan460
if you want an open diff in front you will need to get this to use 4.10's http://broncograveyard.com/bronco/i-...3-93-5-38.html and if you have never set up a diff and gears before, you might want to find someone who has to help you. you can't just bolt them in and be done with it.
Old May 27, 2010 | 11:18 AM
  #39
JereThei's Avatar
JereThei
I know how to set them. I know its not just bolt in and go. I have only replaced stockers before, and i heard something about 4:10 not fitting the stock housing so i asked.
Old May 27, 2010 | 11:31 AM
  #40
fatdan460's Avatar
fatdan460
they fit the housing, just not the carrier. most half tons and broncos came with 3.50 gears. the case split for a dana 44 is 3.91 and down and 3.92 and up. get the right carrier, and you are good to go
Old May 27, 2010 | 11:48 AM
  #41
JereThei's Avatar
JereThei
alright sounds simple then. any idea for limited slip etc. for the front, or do we recomend keeping it open? Should I run the 8.8 or a 9 inch rear? thanks for all the info btw guys
Old May 27, 2010 | 11:58 AM
  #42
fatdan460's Avatar
fatdan460
for the rear i would go with the nine inch, unless you happen to find a 4.10 limited slip disk brake 8.8 for cheap. don't know if the pickups had factory disks though.
for the front, if you keep it open it will be less likely to break parts, but a ford track lock l/s would give a little more traction without being too hard on the axleshafts.
Old May 27, 2010 | 12:03 PM
  #43
Prozon's Avatar
Prozon
The 8.8's came with disc brakes in Explorers, I don't think so in trucks.
Old May 27, 2010 | 12:22 PM
  #44
fatdan460's Avatar
fatdan460
that's kind of what i said
Old May 27, 2010 | 01:42 PM
  #45
Prozon's Avatar
Prozon
Well I was telling you that Explorers came factory with them, which you didn't mention and that pickups did not.
