f-100 1976 stepside
Old May 22, 2010 | 10:32 PM
23 teaser's Avatar
23 teaser
Talking f-100 1976 stepside
i have 2 question i have a 1976 f-100 step side with the wooden bed all orginal it came with 360 how many where built i have a hard time finding them and i am putting in a 390 4v what is the compression cc in the heads also i am building a 23 t bucket (23 teaser)
Old May 22, 2010 | 10:48 PM
76f350spercamprspeal's Avatar
The Term your lookin' for is FlareSide.
StepSide, is a Chebbie (Chevy) Term.
Welcome to FTE.
FlareSides aren't rare.
The 360 & 390 are exactly the same except for the Bore & Stroke, so just do some work to your 360...
Post up your VIN & I'll decode it for you.
Old May 23, 2010 | 12:17 AM
bamaf150's Avatar
bamaf150
Welcome to FTE.
Again, the bore is the same, only the stroke is different.
Old May 23, 2010 | 01:10 AM
CheeksMcDuke's Avatar
CheeksMcDuke
Go with the 390. The 360, while bulletproof, has a limited power potential. Mine had 3 dead cylinders and most of the timing gear's teeth were in the oil pan but it still ran and got me from place to place. The 390 was designated a HiPo engine and modified with better cylinder heads, solid lifters and even 6V induction before the limited run 406 and the vaunted 427. You can still make some pretty good numbers with basic bolt-ons (headers/alum intake/bigger carb/better heads). Oh and a good cam swap.
What are the #'s on your heads and what did the engine come from? D2TE AA heads are 68-72 cc's and depending on what kind of pistons you have/head gasket thickness compression is anywhere from 9.0:1 to 10.5:1. The most common is 9.5:1, though.
skidoorulz
121
Mar 15, 2022 12:59 PM
23racer
Nov 7, 2011 05:18 PM
23 teaser
17
May 26, 2010 10:43 PM
jdhudall
Oct 17, 2008 09:25 PM
Cartman
May 19, 2000 06:36 PM
