1978 - 1996 Big Bronco
95 Bronc ABS line routing
Old May 22, 2010 | 05:41 PM
Nitehawk770's Avatar
Nitehawk770
Exclamation 95 Bronc ABS line routing
Have a 95 Bronco, has ABS block on the frame right next to the driver's shock tower. Need to know the correct way to situate the lines to get them run. (what hole goes to what side)
There's 2 smaller holes on the extreme right and left, and a larger one in the middle. I'm assuming the larger one is for the rear line.
I've been scouring the net for over an hour and need to get this done tonight. any help anyone can give me is much appreciated.
Old Jun 2, 2010 | 04:19 AM
g_k50's Avatar
g_k50
Bumping It. How did this turn out. If you need something in a hurry check the local library not here.
Old Jun 3, 2010 | 01:12 PM
Nitehawk770
well i got it figured out, had to go to my high school to get access to AllData......found out I routed them wrong, explains why the ABS light is on. Now I just have to get them put in the right holes and i should be set.
5.0 Heaven
Sep 29, 2013 12:34 PM
Ortarheel
Mar 13, 2013 03:56 AM
Richwho2
15
Apr 30, 2003 09:30 PM
