I recently replaced my oil cooler after puking grey coolant out of my degas. I took the EGR cooler to the Ford Tech to be pressure tested. He told me I did not need to test it. He said that he has never seen a 2003 EGR cooler fail, only 2004-2007. He also told me that if it were bad, it would be clean inside due to the coolant leaking through it. Mine had soot in it. I was only loosing a small amount of coolant after a 400 mile trip. If the EGR cooler was bad, would I loose lots of coolant and blow white smoke from the exhaust? I hope that I don’t need to replace the EGR cooler, after getting everything back together. What do you think? The puking coolant had a strong smell of exhaust soot, and the intake manifold was caked with exhaust soot. Is that the normal smell of coolant when the oil cooler is clogged, or is this a sure sign of a a failed EGR cooler ? I want to make sure I did not miss anything. 2003 6.0 PSD 120,000 miles.
When I was replacing my oil cooler, I spoke to several tech's, dealerships, parts departments etc... regarding the 2003 EGR cooler. All of them told me that they had never seen a 2003 EGR cooler fail so I put mine back in too. Does this mean that they don't fail, of course not, but to me it sure sounds like the 2003 EGR coolers are a far safer bet then the other years. I don't have the answer to your question, just wanted to share what I had researched.
I just pulled the EGR valve to look at the inside of the mainfold. I cleaned the inside of the intake manifold when I replaced the oil cooler due to thick caked soot in the manifold. I have around 100 miles on the truck after doing the oil cooler. When I looked inside the intake manifold there was a light dusting of black soot over the entire inside surface of the intake manifold. Is it normal to have black soot on the inside of the manifold after 100 miles? Would this reflect a failed EGR cooler with the history of the smell of exhaust in the coolant prior to doing the oil cooler?
Dry soot is normal, wet or damp soot is bad egr cooler. Rule of thumb is to replace both at the same time since the labor over shadows the price of the part plus your down time.
I hope your cooling system (including that EGR cooler's coolant side) was properly cleaned after your oil cooler failure. That makes one heck of a gooey mess that will cause problems down the road if it isn't cleaned out.
There have definitely been posts here of 2003 EGR cooler failures over the years. No doubt it is somewhat uncommon. IMO, I would put the bulletproofdiesel EGR cooler in, if I already had the OEM one removed. I have been "holding off" on my opinion on that cooler so that enough time would pass to get a reasonable "picture" of how it works and if it is reliable. Now, I think enough time has passsed and I have never read anything bad about it.
I too would do the bulletproof cooler if I was doing this over again. I deleted mine but would go the other route knowing what I know now.
Rickatic, I am curious as to why you would do it different now. I talked with the 'Bulletproof' guys and they said theirs only cools to about 80% of what the oem egr cooler does. Would this be enough? I have an '03' but have had my egr unplugged for about 5k miles, per the instructions in the tech part of this site, but am thinking of going the delete route to head off any problems as I also want to get a tuner. I will be doing the oil cooler too while I am there. I have already done the exhaust, coolant filter and oil-bypass filter. By the way there was hardly anything in the coolant filter after about 2,500 miles. The truck only has about 58,000 miles total.
Just curious about which way to go, delete or BP.
Thanks for any input here.
