6.0 Oil Pressure Problem
Old May 21, 2010 | 08:26 AM
Lawman7346's Avatar
Lawman7346
Cool 6.0 Oil Pressure Problem
Ok, I think I have more than one problem here.
#1 Oil Pressure gage on shows 0 (off) at idle and center at anything above idle (on).
#2 Looking at the ICP Pressure it is close to the desired pressure until you get above 2750 rpm then it drops to about 600PSI with the ICP regulator commanding 85%. Through the rpm range below 2750 the HPOP is making upto 1800 LBS of pressure.
The low pressure oil pump, ICP regulator and the High pressure discharge tube has been replaced.
Anyone have any ideas?
Old May 21, 2010 | 09:02 AM
cartmanea's Avatar
cartmanea
Seems like you still have a HP oil leak. What year truck? You might need to do the air pressure test to find the leaks.
Old May 21, 2010 | 09:56 AM
rickatic's Avatar
rickatic
I am going with a leak somewhere as well. 1800psi from the HPOP at 2000rpm seems low to me. Maybe Cheezit will chime in soon.
Old May 21, 2010 | 09:58 AM
Lawman7346's Avatar
Lawman7346
It is a early 2004.
Tugly
223
Aug 18, 2019 07:36 AM
fordpride
15
May 23, 2016 01:00 PM
jayc3169
Jun 2, 2014 08:38 PM
ghostrid
Feb 11, 2014 09:56 PM
Tugly
39
Feb 1, 2014 11:23 AM
