Rear Coil Springs?
Old 05-20-2010, 06:50 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
Rear Coil Springs?
When I first got my truck two years ago I noticed it has rear coils next to the shocks on the rear axle.The bottom mount is just held on by a u-bolt from what I can see.Is this factory or something a previous owner did?I don't really recall seeing any other trucks like this,but then again I never looked hard enough.If it makes any difference,rear axle is a 9",truck is a 1980 F100.Thanks in advance.
Old 05-20-2010, 07:12 PM
cadunkle's Avatar
cadunkle
cadunkle is offline
Previous owner probably too cheap or lazy to either replace or rearch the rear springs.I would remove them and see how the truck rides and sits. If it sags then you know waht you need to do.
Old 05-20-2010, 07:41 PM
KevinGnWV's Avatar
KevinGnWV
KevinGnWV is offline
The village idiot.
Sounds like hillbilly helpers. They used to sell coils to go around your shocks, they may still. But a spring beside the shock.....hmmm. Could be an after market thing maybe. Who knows.
Old 05-20-2010, 07:49 PM
Fordzilla80
I didn't think it was stock.I think the truck used to be a farm truck,so it doesn't surprise me if they are aftermarket.Here's a pic of them.It's just real hard to tell cause they're just as dirty as the rest of the suspension.
Old 05-20-2010, 09:13 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Like said, Hillbilly helpers ...
-Enjoy
fh : )_~
Old 05-20-2010, 10:28 PM
Fordzilla80
Okay,thanks y'all.I think they might be some type of overload assist,because I don't think they touch the frame.But i'm not too sure.Thanks again.
Old 05-20-2010, 11:30 PM
bghnkinf250's Avatar
bghnkinf250
bghnkinf250 is offline
Take a look, if they are not loaded while it is sitting (like you said, touching the frame) they are not hurting anything and probably will help with a load in the bed. Another option is to put airbags in IF you even want some extra load help.
Old 05-21-2010, 12:07 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
I had those on my 83 F-100, they are just a different kind of helper springs. You can still find them in some auto parts stores.
Old 05-21-2010, 01:30 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Originally Posted by Fordzilla80
I found a set of those under a crashed 81 F100. I swapped them in under my 80 F150. They really help keep the rear from squatting when I hook up the trailer and load a car on it. Otherwise, they just sit there not doing much......
Old 05-21-2010, 08:41 AM
Fordzilla80
Alright guys,thanks alot.This truck most likely won't ever see a heavy load aside from lumber,and I don't have any plans on pulling trailers with it.It had a rough last 30 years,i'm gonna give it an early retirement.
Old 05-21-2010, 09:40 AM
fellro86's Avatar
fellro86
fellro86 is offline
They do still sell them, they are an add on helper spring, sell for around $25. I added them to my van to make up for sagging monoleaf springs... they ride better than the helper leafs that clamp on the leaf, and probably less hard on the leaf spring than those clamp on helpers...
Old 05-21-2010, 05:20 PM
fordsgofaster's Avatar
fordsgofaster
fordsgofaster is offline
That's a neater set up then mine, but yeah definitely load helpers.
Old 05-22-2010, 12:23 AM
jaredraulston's Avatar
jaredraulston
jaredraulston is offline
I had 5800 pounds in the bed of my '82 f350 the other day. I was wishing for helper springs!
F10070
05-20-2014 01:40 PM
dillinewton
Offroad & 4x4
01-29-2010 01:25 AM
Spudco
02-28-2004 01:47 PM
fordtrck302
08-15-2002 03:35 PM
butaford
07-01-2001 08:42 PM
Quick Reply: Rear Coil Springs?
