Offroad & 4x4
custom lift
Old Jan 24, 2010 | 09:44 PM
dillinewton's Avatar
dillinewton
custom lift
i have a 79 ford 150 that i am puttin 3/4 axle under, coil springs in the front and leafs in the rear. I have 9 inch leaf and 9 inch coils im going to flip my shackles on the back side of my rear axle, what should that gain me in the front. and what can i do to the front to make the truck sit level? thanks alot
Old Jan 24, 2010 | 10:42 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
You could drop the front spring buckets.
Old Jan 24, 2010 | 10:45 PM
79f350wheeler's Avatar
79f350wheeler
you could just put leafs in the front and get rid of those coils.
Old Jan 25, 2010 | 12:20 PM
Blueoval_boy_64's Avatar
Blueoval_boy_64
One easy way to drop the front bucket is build a template of the hole patern behind the stock bucket out of 3/16" plate, then bolt the lower holes to the upper holes on your bucket. cut the bottom half and throw a gusset on the top and you've got an extra 4" of lift, and it'll bolt back up to your frame in the origional spot. Did that on mine to compensate for the rear. You can also build a coil spacer for the bottom
Old Jan 25, 2010 | 06:47 PM
dillinewton
are you talkin about the fron bucket of my rear springs? and do you have a clue how much lift ill get if i just flip my back shackles? thanks could you go over that one more time i didnt quite pick up on that thanks alot sorry to be a pain
Old Jan 25, 2010 | 07:36 PM
dillinewton
oo sorry i think i understand i tihnk sorry i miss read it, but what you mean by cuttin the bottom of the plate and that part then where do i put it after that?
Old Jan 26, 2010 | 09:25 AM
Blueoval_boy_64
So your going to get a scrap piece of metal that will cover the 4 holes in your coil bucket. Place it behind the bucket and drill the 4 holes. Once this is done take the plate off the back of your bucket and bolt the bottom holes of the plate to the top holes of the coil bucket. Once you have weld the plate to your bucket. After that put a small gusset between the top of the plate and the top of the coil bucket for support. Once this is done trim the bottom of the coil bucket below your new plate and you will have a very nice looking coil bucket with a 4" drop that is very strong and bolts up to the origional location. You should get around 3-4" of lift by flipping the shackles. I just don't recomend this if you have lift springs since it'll really push your axle forward and won't be very centered in your wheel well, but this can be done with junk yard parts. Don't do what I did and spend the $125 on a set of brackets
Old Jan 26, 2010 | 10:22 AM
dillinewton
what if i flip both front and rear shackels would like recenter it? thanks alot
Old Jan 26, 2010 | 10:28 AM
dillinewton
if not what do you think i should do to get some extra lift?
Old Jan 26, 2010 | 10:48 AM
Blueoval_boy_64
If you already have 9 inch lift springs, just put a 4 inch block in it. You only have a shackle in the rear so you can't "flip both."
Old Jan 26, 2010 | 06:15 PM
going up 2!'s Avatar
going up 2!
x2,just put a coil spacer up front
Old Jan 28, 2010 | 11:51 AM
Blueoval_boy_64
Here's a pic of my coil bucket with a 4 inch drop
Old Jan 28, 2010 | 09:26 PM
dillinewton
sweet thanks alot
Old Jan 28, 2010 | 09:30 PM
dillinewton
couldnt i kinda do this to any height to match my shackle flip in the rear? it i mean 4 inch and less cause i wouldnt want any less strength to it?
Old Jan 29, 2010 | 01:25 AM
Blueoval_boy_64
It's just easier with the 4 inch because of the hole seperation. you can do less, and drill 4 different holes
cranemaster
Sep 28, 2014 10:47 PM
69FF100
Jan 24, 2014 02:06 PM
albinorhino
Dec 30, 2011 08:01 PM
Bender99
Offroad & 4x4
Sep 23, 2009 04:10 PM
HardFordCore
Nov 18, 2005 08:01 AM
