Axle code ?
Old May 20, 2010 | 05:35 PM
5.4f250sd's Avatar
5.4f250sd
Axle code ?
Hi guys I am a newer member and I have been over in the superduty forum, but I have a ? about my business partners truck. It is a ext cab long box 2005 f150. He has a axle code #25. I was wondering who made the axle and what is the gear ratio. Also what are the trans ratios?
We pull a 9500# bob cat around and I just bought a newer f250 (06) and would like to know how they are going to compare. We both have 5.4's and I have a torqshift trans. Thanks and cheers!!!!!
Old May 20, 2010 | 11:17 PM
5.4f250sd's Avatar
5.4f250sd
someones got to know something about this axle!!!!!
Old May 20, 2010 | 11:32 PM
5.4f250sd's Avatar
5.4f250sd
ok I searched around and found that the 25 is a 4:10 but i don't know who makes it.
Old May 22, 2010 | 09:16 AM
Greg B's Avatar
Greg B
I'm not sure of the manufacturer, but most likely it's made by Dana. If it's 4.10, it's a 10-1/4" ring gear differential that's found under max payload trucks. It should also have 7 lug steel wheels.
Old May 24, 2010 | 07:56 PM
5.4f250sd's Avatar
5.4f250sd
Thanks greg that clears stuff up. I have found the transmittion gearing and it is a 7 bolt lug with 4.10's.
Old May 28, 2010 | 01:19 PM
chops0523's Avatar
chops0523
How many bolts are on the diff cover? Dana diff's always have 10 bolt covers. The 10.25 is a Ford diff and should have 14 bolts, some had 12.
Old May 28, 2010 | 07:18 PM
Greg B's Avatar
Greg B
Thanks for clearing that up, chops. I honestly did not know the supplier for the differentials with Max-Payload. Since a lot of parts and assemblies are sub-contracted, Dana could have possibly made it. But even so, it's a Ford design. So no matter who made it, it's a Ford differential.
Old May 31, 2010 | 10:22 AM
chops0523's Avatar
chops0523
No problem guys, glad I could help!
Old Jun 1, 2010 | 08:29 AM
5.4f250sd's Avatar
5.4f250sd
Thanks guys this is good info I thought it was the same as mine for some reason ,but I should of looked closer!!!!! It must be pretty strong with a 10.25 ring gear!
nash22
Oct 12, 2011 07:58 PM
DOHC330MustangGT
Apr 15, 2005 06:40 AM
sleepysal
Sep 15, 2003 10:44 AM
Jim McCarty
Jul 22, 2003 06:33 PM
snoodick
Dec 26, 2000 09:22 AM
