Second set of tires and rims
A second set isn't a problem. Don't forget your truck has tire pressure sensors. You'll want the second set of wheels to have the sensors. And you'll need to be able to retrain the sensors to the truck when you change them over each spring/fall. Unless you don't mind putting up with the indicator light and/or beeping from the message center.
Beyond that, there's no problem.
Speedometer
Perhaps I dating myself, but it use to be that when you put different sized rims/tires on your vehicle, the speedometer would not give you your true speed. The speedometer was calibrated with the factory sized rims/tires and increasing or decreasing the diameter of the wheel would make the speedometer indicate a greater or lesser speed than you were actually traveling.
With all of this new electronic stuff on the vehciles now days, perhaps this is taken into account.
Bill
Bill
I was thinking the same thing!!
Bill
Bill
actually the overall diameter in the tires that Ford uses are pretty much the same, so there should be very little to no effect on the speedometer if swapping the factory sizes. For the 20" and 18" 4x4 sizes, the 275/55/20 and 275/65/18 factory tire sizes are both roughly 32" diameter tires.
Read your owner's manual about the sensor reset tool...
HarleymanPearce
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
01-13-2011 06:13 PM
the Goat
1999 to 2016 Super Duty
20
08-27-2010 10:35 PM
