Jag IFS install help!
  #61
Old 07-14-2010, 02:37 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
351W Jag IFS steering shaft interference
I know that someone has a 351W and Jag IFS setup but can't remember who it was...I am curious to know what was done to cure the interference issues that I am facing. I have been on borgeson's website and I know that stuff can be bought, but first wanted to see what headers or exhaust manifolds are being used. I have a pair of ceramicoat shorty headers for a mustang but my collector flange is in the way...bummer...so I put on the stock manifold and it has the same problem...bummer again...I thought about using an offset mid shaft but thats a bit pricey. I will do that if I have no other choice, but wanted to find another person with the same issue. Also I thought about offseting the 351W to the passenger side a bit but then it gets tight on that side.
I don't have any engine mounts yet and won't until I figure this out. Thanks! Jeff
  #62
Old 07-14-2010, 05:26 PM
49willard's Avatar
49willard
49willard is offline
Jeff,
Look at the log style manifold with the rear dump. That will get you away from the pinion on the Jag.
  #63
Old 07-14-2010, 08:10 PM
Jeff and Nicolle
Okay what years are we talkin? what vehicles I assume older ones?
Thank you sir! were these available on a 302 also?
  #64
Old 07-14-2010, 08:35 PM
49willard's Avatar
49willard
Jeff,
I am not the go to guy on sbf manifolds. My f-1 with the Jag IFS is set up with a sbc. That said however, if you google 351 ford exhaust manifold you will see what I call the "log" style, with a rear exit. They were used on trucks and vans in the mid 90's. They were also used on 302's. I am not personnally aware of which specific log style will give you the best flow/performance for your engine. Hopefully others on this forum can help more.
  #65
Old 07-14-2010, 09:22 PM
Jeff and Nicolle
hey thats cool...I will do just that...thanks again! I hope its that easy, just a diff manifold.
  #66
Old 07-17-2010, 01:00 AM
Aussie 53's Avatar
Aussie 53
Aussie 53 is offline
Sorry Jeff I can't help you there when it comes to which manifold to use, as I had custom extractors specially made up clear all the steering and other issues.
  #67
Old 09-27-2010, 09:44 PM
Jeff and Nicolle
not sure but i think there are guys using the crown vic ifs on 57-60's
don't know how wide your frame is. Look at some pics in my albums.
I am struggling with the steering linkage header interference. I am using a 351W , a 302 is a little narrower and might be an easier choice for fit, but i will figure it out, just not experienced with altering so many things at one time. I wish there was a simple solution to this cause im tired of thinkin about it. I guess if it was easy then everyone would do it though.
I didn't want to spend a fortune on steering joints but that may be the answer.
  #68
Old 11-11-2011, 09:54 AM
shelly ellison's Avatar
shelly ellison
shelly ellison is offline
what year jag and model will fit a fioo 1952 32 wide frame help thank for the help. I found a 1991 xj6 ?
  #69
Old 11-11-2011, 12:53 PM
Jeff and Nicolle
Mine is a '79 I think up to '86. Maybe some other JAG IFS guys will chime in here! Welcome!
  #70
Old 11-11-2011, 03:22 PM
barnfind 51's Avatar
barnfind 51
barnfind 51 is offline
I have a 86 XJ6 .. some say to that year back. i believe that 46 Steel has a later one in the 90'S not sure . May be will come on board and fill us in.
Happy Veterans Day And Thanks for your Service!!
  #71
Old 11-11-2011, 03:40 PM
barnfind 51
Sorry for the mistake .. He is 48 Steel not 46 and I believe he used a 80 model..He has a pretty good tech on it. I know there are other that have done the swap. I would get out the old tape and check it out.
  #72
Old 11-12-2011, 07:59 AM
48 Steel's Avatar
48 Steel
48 Steel is offline
I'm using an 80 xj6 Jag IFS and a 79 Ford 351M stroker. In my gallery if your interested.
_____________________________________________
46 Ford Tudor - Street Rod
48 Ford F1 - Dark Side
"Happiness - 3 pedals and a 5 speed"
  #73
Old 11-12-2011, 08:34 AM
Jeff and Nicolle
I got your PM, I think "shelly ellison" is asking for help! My IFS is done and I am working on my wiring decisions..
  #74
Old 11-12-2011, 10:15 AM
rhopper's Avatar
rhopper
rhopper is offline
Mine is from a 1984, series III xj6. The later models, after the series III, have a different crossmember and won't work. The later model is not a series IV, like you think it would. I think it's something like series 40, or xj40.
Now about my comment of not working, the series III is a proven match for our trucks. The later series has a similar crossmember, but not the same. It may not be the easy bolt in that the series III is, but with some mods it may work as well. I don't know if any one has tried it, but you may want to be the first!
skidoorulz
24
03-19-2015 05:03 AM
dipstick429
New Member Introductions
01-09-2015 11:26 AM
429unibody
37
11-11-2014 07:31 AM
Old93junk
15
12-08-2013 11:58 AM
scottlathrop
20
11-23-2013 12:42 PM
Quick Reply: Jag IFS install help!
