Jag IFS install help!
Old May 20, 2010 | 09:17 PM
twise's Avatar
twise
Hey Jeff, check in your "friends and contacts" section.
Old May 20, 2010 | 09:31 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
I just checked and there is nothing about it. I do have some previous msgs but no big deal, its just wierd that you sent it to me and I didnt get anything. hmm
Old May 20, 2010 | 09:32 PM
Jeff and Nicolle
I found it under friends and contacts, my bad !
Old May 21, 2010 | 07:04 AM
twise's Avatar
twise
Cool, I thought it was strange too. But I don't send too many messages so just figured I had done something wrong.
Old May 21, 2010 | 07:15 AM
Jeff and Nicolle
Do I have to make my own engine mounts for the Jag IFS? I am gonna use a 302 or 351w
Old May 21, 2010 | 08:28 AM
49willard's Avatar
49willard
Jeff,
I made my own however I could have purchased aftermarket weld or bolt in mounts. In my case I have a sbc. Hopefully someone will chime in that is setting up the Jag IFS with a sbf. I suspect that you will want to go with the bronco pan/oil pump to clear the Jag IFS and keep the engine low in the chassis. I also boxed the front of my chassis however that is not a must do.
Old May 21, 2010 | 03:12 PM
Jeff and Nicolle
I got the suspension home and this wierd bolt that goes inside the back rubber suspension mounts must have got dropped somewhere. Its got a triangular steel wedge where the bolt head would be. I looked all over for it...no where to be found...hope I can find another. Or a suitable replacement...Its always something! I didn't get the master cylinder/booster because I want to use a new frame mount unit. I got the whole section of steering shaft between the rack and the end of the steering column. got the sway bar and its mounts got the wierd brake line ends that were talked about. didn't get the power steering pump, I will use a ford pump,whatever is mounted to motor I get.
Any feed back on parts I didn't get please let me know, it will be available for a short time. I thought about the steering column, but these guys were tired of me being meticulous! Typical salvage guys...If ya can't torch it or saws-all it then it is too tough for them. But they were pretty cool all in all!
Old May 21, 2010 | 03:15 PM
Jeff and Nicolle
Is the bronco pan a rear sump? are there other choices...truck? or is the bronco pan on its own?
Old May 21, 2010 | 04:37 PM
52 Merc's Avatar
52 Merc
I would go back and get the Jag p/s pump. It may operate differently with pressure or volume than the Ford pump, and you really want matching parts to your Jag steering. Also, you won't have to have custom lines made with metric fittings on one end and sae on the other.
Old May 21, 2010 | 05:02 PM
rpol7966's Avatar
rpol7966
The Jag pump is nothing more than a GM Saginaw pump. They are very common and have been used by many different manufacturers since the '60s. It's one of the easiest parts to find and adapt to whatever engine you are using.
I'm not sure but it's my understanding that everything on the Jag IFS is SAE thread EXCEPT for the brake calipers and brake hose fittings which are metric. Tim
Old May 21, 2010 | 05:33 PM
Old F1's Avatar
Old F1
Originally Posted by rpol7966
a GM Saginaw pump. have been used by many different manufacturers since the '60s. Tim
…………………………….like on a 1974 ford full sized car with a 460!
Old May 21, 2010 | 06:24 PM
69supercj's Avatar
69supercj
What year(s) and model(s) of jag should a guy look for if he's going to install it in a '58? Seems like I seen one of these setting somewhere real close to hear and its been there for a long time. Might have to hit the guy up about buying it.
Old May 21, 2010 | 06:48 PM
  #28
rpol7966's Avatar
rpol7966
The Jag IFS that is preferred is the series 3 which was used in the '79-'87 XJ6 and the XJ12 from around '79-'92. The XJ12 was a 2 door with the 12 cylinder engine. The 12's suspension was the same as XJ6 except that it had heavier springs to support the heavier 12 cylinder engine. Tim
Old May 21, 2010 | 06:50 PM
  #29
55 f350's Avatar
55 f350
closest thing i seen to a rear sump pan jeff is the pan from an 80-94 or so 1/2 ton ford .it has a small hump at the front but it's as close as you can get that i've seen . there was a guy here that cut the fromt sump , hump pimple , whatever ya wanna call it , out and flatten it too fit his truck ......... so ..............
Old May 21, 2010 | 10:46 PM
  #30
69supercj's Avatar
69supercj
Will these jag front ends work in the '57-'60 F-100's?
