fuel tank removal
Old May 20, 2010 | 09:04 AM
backdraft341's Avatar
backdraft341
fuel tank removal
i have a 1986 f-150 supercab with a 302 efi auto trans 2 wheel drive. i need to remove the front fuel tank. can i run my truck with the front tank removed till i repair it? if so do i need to plug the fuel lines to the front tank? has anyone ever rebuilt the fuel pump in the front tank? i know the rebuild kit is cheaper. also is there a way to test the front tank fuel pump once its removed? thanks
Old May 20, 2010 | 11:28 AM
baffledinpa's Avatar
baffledinpa
Yes, You can run the truck w/o the tank, I did with my truck for several years.
Yes, You need to plug the lines somehow to prevent fule from leaking.
I've replaced the front pump before but never rebuilt one. I pried the old pump off so I could reuse the stock sending unit.
I've never tested one out of the vehicle but maybe some of the older more experienced members can help you there.
jerwiltho
Feb 21, 2013 09:08 AM
linckeil
Aug 23, 2010 09:43 AM
danlee
Dec 16, 2009 10:09 PM
mjfitting
16
May 6, 2007 06:14 PM
amcf150
17
May 3, 2005 05:41 PM
