1978 - 1996 Big Bronco
O2 sensor question
Old May 19, 2010 | 09:29 PM
76f250highboys's Avatar
76f250highboys
O2 sensor question
Hello all, I have an 85 bronco with the AOD trans and fuel injected 302. I had my 14 year old son swap out the O2 sensor and he is not sure what wire it was connected to. I dont know because I was never down there. He found one that is black and runs down from the firewall. I was wondering if anyone out there had a picture of this so I could be sure I have right wire or not. Thanks in advance for any help.
Old May 19, 2010 | 09:53 PM
greystreak92's Avatar
greystreak92
The O2 sensor has a three-wire connector with a GREY/YELLOW, GREEN/PURPLE, and a BLACK wire. The GREEN/PURPLE sends readings to the ECM. The GREY/YELLOW is the power in from the ignition to heat the sensor. The BLACK is the negative (ground) to complete the circuits.
Old May 19, 2010 | 10:23 PM
Conanski's Avatar
Conanski
No.. I believe these early EFI trucks had 1-wire O2 sensors, I can't help you identify the wire however.
Old May 19, 2010 | 10:43 PM
76f250highboys
After consulting my haynes manual,the sensor is correctly called an HO2S or HGEO sensor. The only three wire sensor I found was green,orange,black, but I think that is my MAP sensor. My o2 sensor has one black wire. Im having the same problem as Cdy1 is having...engine running rich.
Old May 19, 2010 | 11:39 PM
greystreak92
Older O2 sensors that do NOT self-heat simply send the signal back to the ECM via a single wire. Since the voltage generated by an O2 sensor is dependent on the chemical reaction that occurs when the sensor reaches a certain temperature, early units don't actually start sending signal/information until the exhaust system has heated them.
I have no information for the 85 EFI models so I was referencing 86 model year which DOES utilize a HEGO sensor (self heating unit that requires the other two wires to heat the sensor so it begins sending information to the ECM almost immediately).
Old May 20, 2010 | 10:32 AM
Kemicalburns's Avatar
Kemicalburns
on my 94 the o2 sensor wire is loomed in with the starter cable. not sure if that will help you or not. the plug for the o2 is specific to only that part so i would assume if it fits then you have the correct wire.
Old May 20, 2010 | 12:23 PM
greystreak92
Yeah, Kem that's what I thought too but after what the guys said about it, the 85 EFI models (since they would be the first models with an O2 sensor... carb'd models didn't need one) could well use the old oxygen sensor that doesn't have the pre-heat circuit/element in it. If that is the case, the sensor could very well have only one wire running to it from the ECM.
tsedgar
Dec 17, 2012 04:39 PM
Paul52097
Dec 10, 2012 03:19 PM
dancing4raiin
Dec 1, 2012 09:38 AM
n_ueland015
Electrical Systems/Wiring
Aug 11, 2007 02:08 AM
