Identify a hub by partnumber
Here are some pics:
The part number says C4TA-1106-DK
This is not the Ford part number for the hub, it's the ID engineering number for the hub.
I google it and find some identifyer-pages where it said that this should be a part of 1964 Ford Truck front axle
is, but I am not sure.Ach du lieber! This hub did not come with any axle, it's the front hub used with the brake drum.
These hub is used in 1929 Hot Rod, and it is very damaged inside. I have some measurements if required. So we need a "new" one. So if someone knows exactly where it came from and does have one for sale that would be great. Thanks from Germany!
Fits: 1964/67 F100 2WD ONLY! 1961/63 F100 2WD is NOT the same / No Ford Dealer or obsolete parts vendor has any.
This hub was originally (1964/65) available by itself. In 1966, Ford obsoleted the hub, only sold it with the brake drum as a hub & drum assy.
C6TZ1102E (replaced C4TZ1102A & C6TZ1102B) .. Hub & Drum Assy / Obsolete / Fits: 1964/67 F100 2WD / No Ford Dealer or obsolete parts vendor has any.
You're prolly going to have to buy a used hub & drum from someone, then use just the hub.
One of the following members of this forum might have an extra: camperspecial65, garbz2, Bill W, banjopicker.
