easiest place is right behind the rubber splash guard in your drivers side fender well. Just behind the shock mount will be your #4 cylinder. Easy access.... Especially since you gotta tap some threads in there.
Anyone got a picture of their EGT gauge installation at the back cylinder? I'd like to tap the exhaust manifold for it before I install it but I want to make sure I'll clear the cab/fender/steering shaft/shifter etc
Ive got another thread about the pyro from a while back. It should answer any questions. I hooked up the probe to the pyro and heated it with a small propane torch and it seemed to work fine.
