EGTs
Old May 19, 2010 | 02:09 PM
johnboggs21's Avatar
johnboggs21
EGTs
What are you guys with pyros seeing for EGTs? Im curious if my gauge aint reading right, or if i need to relocate the probe. I put it immediately after the manifold.....
Old May 19, 2010 | 07:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle
That is a very hard to answer question.
A run up the interstate at 70 MPH goes somewhere between 300 and 1200.
300 on the down hill side, 700 to 1200 on the uphill side.
Mine is in the exhaust manifold sticking in the #8 exhaust port.
Old May 19, 2010 | 07:58 PM
johnboggs21
What do ya see on flat land? Or is taht a rare thing in your area lol. Seems like im lucky to hit 300.
Old May 19, 2010 | 08:29 PM
Dave Sponaugle
I gotta drive a couple hundred miles to get to flat ground.
The only place flat in WV was man made.
They won't let me drive on the runway at the airport.
Old May 19, 2010 | 09:23 PM
swooshcmk's Avatar
swooshcmk
Sounds like you tried?
Old May 19, 2010 | 09:52 PM
powerstroker100's Avatar
powerstroker100
Subscribing, I will be installing my gauges soon too and this is something very important, now I'm not sure if this would apply for this 7.3l engine but in 6.0 land if it was in 1400 for a few seconds thats not good at all basically 1400 was the bottem line I was seeing around 900 in average what temperatures am I looking for in this engine?
Old May 19, 2010 | 10:54 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you guys don't have turbos (johnboggs21/powerstroker100.)i dont think us n/a guys have to worry much about EGT's?
Old May 20, 2010 | 06:16 AM
johnboggs21
well the only reason i put a pyro in was because I wanted to play with the fuel screw some.
johnboggs21
Oh and apparently the N/A IDIs can get quite warm even stock.
Old May 20, 2010 | 10:15 AM
kenpobuck's Avatar
kenpobuck
I get any were from about 300-900 running down the highway at 60 mph. It is all rolling hills here with some pertty steep ones at times. On those i can hit 1200 ( like when running up what we call "the cut in the hill" on south bound I75 coming into Kentucky out of Ohio).
Old May 20, 2010 | 12:14 PM
Sycostang67's Avatar
Sycostang67
Cruising around town I run about 400, 600-800 cruising at 55 or faster. With the probe after the manifold I wouldn't let it go higher than 1100 for more than a couple seconds.
Old May 20, 2010 | 01:39 PM
johnboggs21
yea i havent seen 4 digits yet. Havent really had her under a good load yet either since i put the pyro in. She gets up to about 250 and usually hangs out right there.
Old May 20, 2010 | 05:19 PM
Sycostang67
That doesn't sound right to me at all, the only time my egt's are that low is during extended idling. Is your probe and guage matched to each other? Are they new or used? Are you sure it's hooked up right? My guage, the power wire comes loose once in a while and the guage needle will fall to a default position.
Old May 20, 2010 | 05:31 PM
oreocreaming's Avatar
oreocreaming
for me, idle 200... highway speed (55-70) im at 600-800.... climbing i could be 2000 if i didnt get outta the throttle lol. i keep it at 1100-1200 when im climbing. but i only get that hot when ive got a trailer behind me. ive got my probe out of my #4 cyl. like center of the manifold so i can get exact egt as it escapes the engine.
Old May 20, 2010 | 05:32 PM
oreocreaming
and if you are only reading 250 if your driving it especially if your pulling anything then you got issue for sure with your setup.
