1978 - 1996 Big Bronco
what size tires?
Old Feb 2, 2003 | 04:40 PM
ecsmith0624's Avatar
ecsmith0624
what size tires?
I'm going to be getting the Bushwacker cut out fender flares which will take up to 4" off my fenders. What size tire is going to look and fit right without a lift? What tire will look/fit right after a 4" lift? Thanks for your help. --Eric
Old May 21, 2010 | 04:04 AM
g_k50's Avatar
g_k50
Shouldn't be cutting that Bronco, it's worth more uncut. How about some pictures?
Old May 21, 2010 | 04:11 AM
greystreak92's Avatar
greystreak92
The axles are gonna be able to handle up to about 35-36's after that you are going to start wearing and breaking components prematurely. So no matter how much of your poor Bronco's body you amputate, the axles will only handle so much unsprung weight before you start breaking parts of them.
Old May 21, 2010 | 08:59 AM
Encho's Avatar
Encho
The Southernmost Mod
With 4" lift the biggest size you'll be able to use without rubbing anything will be 35", you will have to consider also re-gearing your transmisions to -at least- 4.56, 4.88 would be most desirable.
Old May 21, 2010 | 10:47 AM
Kemicalburns's Avatar
Kemicalburns
regear your differentials not the transmission :-)
Old May 21, 2010 | 10:51 AM
Rockstone's Avatar
Rockstone
He's from Venezuela, it's probably a translation problem.
Old May 22, 2010 | 11:37 PM
Encho's Avatar
Encho
Thx Kem, i meant that, and thx for clarifying Rock. Yes, here it gets a little mixed up as folks use the term "transmision" to refer to both gearboxes and differentials, i just though it was the same in the US. You guys would have a blast trying to talk to a mechanic around here, i.e. they call the torque converter "the turbine".
Old May 23, 2010 | 01:48 AM
greystreak92
Which in truth it is a turbine designed to generate variable hydraulic pressure (fluid coupler).
Old May 23, 2010 | 08:59 PM
Encho's Avatar
Encho
Yeah, but they don't know that, you ask them, they tell you "it looks like one". But then again, you're just pulling my leg...
