94 e150 airbag sensor location
Old May 19, 2010 | 07:29 AM
94E1504.9L's Avatar
94E1504.9L
can somebody point me in the direction of the front passenger side airbag sensor on a 94 e150..........thank you...
Old May 19, 2010 | 11:58 AM
rebocardo's Avatar
rebocardo
The sensor itself is usually on the driver's side behind the bumper on Ford trucks. I didn't know there was a separate one for the pass. side.
okay, I checked my 1995 CD for econolines
1. Center air bag primary crash sensor -- center of radiator support (16138).
2. Right frame rail primary crash sensor -- right frame rail at B-pillar support.
3. Right cowl side panel safing sensor -- right cowl side trim panel (02344).
4. Driver side air bag module (043B13) -- steering wheel (3600).
5. Air bag sliding contact (14A664) -- behind steering wheel.
6. NOTE: A thermal fuse is built into the air bag diagnostic monitor (14B056). If a short to ground should occur in the air bag deployment circuit, the microcomputer in the air bag diagnostic monitor will send a signal to the fuse causing it to open. The open fuse removes all firing power (battery/backup power) from the deployment circuits. This prevents unwanted air bag deployments due to damaged vehicle wiring.
NOTE: Code 51 is displayed whenever the diagnostic monitor thermal fuse is open and no other higher priority faults exist (consult Diagnostic Trouble Code Priority Table). Code 51 is normally seen after service of a Code 13 condition.
NOTE: If a Code 51 exists and a Code 13 condition has not been serviced, this means an intermittent short-to-ground exists in the air bag deployment wiring. The intermittent short-to-ground must be located and serviced before servicing the Code 51 condition.
NOTE: Since the thermal fuse is built into the air bag diagnostic monitor, the monitor must be replaced to service a Code 51 condition. NEVER replace the air bag diagnostic monitor without first determining the cause for the Code 51 condition. If the short-to-ground is not properly serviced, the short may reoccur, once again destroying the thermal fuse in the air bag diagnostic monitor.
Air bag diagnostic monitor -- under instrument panel (04320) left of steering column.
Old Apr 30, 2023 | 07:33 PM
cadjak's Avatar
cadjak
The 94 E150 only had driver side air bag.
Jamespappleton
Mar 1, 2017 07:45 AM
Stavid
Aerostar
Jan 2, 2012 09:04 PM
underDAWG
22
Jun 24, 2006 10:46 PM
tgolen
Nov 21, 2005 07:38 AM
Jason8705
Feb 28, 2005 08:47 AM
