Air bag light....
Old Feb 4, 2005 | 10:36 AM
Jason8705's Avatar
Jason8705
Exclamation Please Read....
My air bag light is blinking...it blinks twice waits a few seconds then once then waits a few more seconds and does the same sequence, what does this mean?? '94 F-150XLT 5.0EFI
Old Feb 4, 2005 | 03:13 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Code 12 is low battery voltage
Code 21 is Right Cowl Side Panel Front Air Bag Sensor Not Mounted to Vehicle Properly.
Digits are separated by a one-second pause. Codes are separated by a three-second pause.
If you do not know how to deactivate, activate, and prove-out the system this is not a do-it-yourself repair. You can accidentally deploy the airbag . It may be a bad connection, wire, sensor or controller.
Old Feb 6, 2005 | 02:27 PM
honeboy's Avatar
honeboy
There is a fuse
Old Feb 28, 2005 | 08:47 AM
jetrepair's Avatar
jetrepair
Fuse fixed 12 code
There is a 10 amp fuse in the distributor box for the airbag. I replaced it and the code 12 is gone.
