Please help with HIGH EGT's
Old May 19, 2010 | 07:49 PM
  #31
Kwikkordead's Avatar
Kwikkordead
Well, if you are POSITIVE that there are no boost or exhaust drive pressure leaks, then may I suggest you try a PHP chip.
Last time I was driving up Steven's pass empty, not pulling a trailer, I was in stock tune and the EGT was 1000.
6% grade, cruise control on 60 mph.
Just for grins I switched to the 25 HP tow and the EGT DROPPED to 850.
I couldn't believe it so I turned around, went back down the mountain, and came back up, repeating the experiment and it worked.
You might have too hot of a tune, running 80HP like that.
Old May 19, 2010 | 08:15 PM
  #32
renyren's Avatar
renyren
I have an MBRP 4 inch turbo back exhaust and just to make it clear my EGT's will redline in any tune but stock either unloaded or towing.
Old May 19, 2010 | 08:18 PM
  #33
Visseroth's Avatar
Visseroth
and your temps at stock?
Old May 19, 2010 | 08:23 PM
  #34
schlepprock250's Avatar
schlepprock250
Where is your pyro probe located??
Old May 19, 2010 | 08:37 PM
  #35
renyren's Avatar
renyren
Prob is in driver exhaust manifold temps in stock unloaded will get at most just over 1100
Old May 19, 2010 | 08:39 PM
  #36
Visseroth's Avatar
Visseroth
still seems hot to me, like Schlepprock said, where's your probe at?
Old May 19, 2010 | 08:40 PM
  #37
renyren's Avatar
renyren
please see post #35
  #38
schlepprock250
Maybe I'm wrong,but to someone who knows,if the probe is in the maifold will it read a little higher than say in the up pipe?
Old May 19, 2010 | 08:44 PM
  #39
renyren's Avatar
renyren
also forgot to metion borrowed my friends truck wich is an 01 F350 CC long bed with 6 inch lift 35 inch tires same gears edge juice programer I towed my trailer and even climbing a hill with pedal to the floor I could not get temps past 1100. Now I now his tow tune is a lot less HP.
Old May 19, 2010 | 10:21 PM
  #40
kupaa's Avatar
kupaa
Maybe the gauge is not working could you brorrow one from somebody
Old May 19, 2010 | 11:04 PM
  #41
renyren's Avatar
renyren
I called isspro today just waiting for a call back. I don,t know anyone close with EV2's
Old May 20, 2010 | 08:03 AM
  #42
03_PSD's Avatar
03_PSD
Can you get Jody to email you some different tunes so you can try out? To me it seems odd that you can get 1200 on stock setting. I can run WOT all day and only see 1000-1100, but thats with a van turbo w/a ww. I couldn't tell if my up-pipes were leaking untill I pulled my turbo, just a thought. Hope you figure the EGT's out.
Old May 20, 2010 | 01:38 PM
  #43
cjfarm11's Avatar
cjfarm11
Yes you will see higher egts with the probe in the manifold for sure. I had mine post turbo and i could hold it to the floor and never see over 1000* but after i moved it to the manifold a I couldn't believe the difference in heat.
Old May 21, 2010 | 12:02 AM
  #44
renyren's Avatar
renyren
I don't get much over 1100 in stock only in the higher tunes. I just changed the CPS yesterday because I am running out of thing to try. The truck seems much quieter now and temps seem a little better but still get hot. Have not towed yet I will try that tommorrow.
Old May 21, 2010 | 07:12 AM
  #45
03_PSD's Avatar
03_PSD
Here's another observation and a bump to the top. When I switched to 325/65/18's I noticed my egt's would climb faster than before. They are basically 35 x 13 something....
