94 Powerstroke won't stop starting
Old May 17, 2010 | 01:56 PM
Motor2of7's Avatar
Motor2of7
I've been chasing an odd problem for a while. I tried to start the engine, and because of the upper reservoir drain problem I have to crank the engine longer than usual. Anyway, after many years of dealing with this, I recently had the starter continue to turn after I released the key. I had to grab a handful of wrenches in a hurry and disconnect the batteries to make it stop. What I've learned since is that I can reconnect the batteries and everything is fine, but as soon as I turn it over the starter keeps going. The same thing happens if I use the key or jump the terminals on the relay (mounted on the passenger side fender well). From what I can see there is the upper relay on the fender and another relay mounted to the starter itself. I replaced the upper relay with an OEM part with no change in behavior. FORD will only sell the lower relay as part of a complete starter replacement for $250. Before I plunk down that kind of money on a hope that it fixes the problem I'd like some thoughts from the smart folks on this site.
Jeff
Old May 17, 2010 | 02:35 PM
Action4478's Avatar
Action4478
The Starter solenoid should be available at most part stores ..
Old May 17, 2010 | 03:32 PM
bad12jr's Avatar
bad12jr
Take it to a starter shop and just have em rebuild it. Usually only 50 to 75 bucks around here and good as new
Old May 17, 2010 | 05:12 PM
cowmilker08's Avatar
cowmilker08
Mine did that once, the starter was on the way out anyway and that finished it off.
New from an awesome starter shop in my area $170 (Farm-use of course), and now it starts like brand new.
There were metal pieces falling out of the drain hole when I took it off.
Old May 24, 2010 | 10:27 AM
Motor2of7's Avatar
Motor2of7
OK, the new (reman'd) starter and solenoid solved that problem. Now it just won't start. I plan to replace the cam position sensor, which could be why it didn't start when the starter burned out. I think I've read here that the 95+ CPS is trhe same as the 94 but a fraction of the price. True?
Old May 24, 2010 | 12:35 PM
JamesHajek's Avatar
JamesHajek
Never heard that, but i could be wrong. I think they are the same thing. Cost around 25 bucks.
Old May 24, 2010 | 01:41 PM
B Big's Avatar
B Big
I used these #'s to search on e-bay & found a CPS pretty cheap. These #'s come from the Navi-Star Catalog as a direct cross over. Plus some of these #'s are the Ford parts #'s.:
AP63400
1825899C93
F7TZ-12K073A/B
The top # is the Navi-Star (International) part #, I don't know about the middle one, the bottom one is the Ford parts' #.
Good luck!
B
Old May 25, 2010 | 12:30 AM
Motor2of7's Avatar
Motor2of7
I seem to be chasing a string of problems. I replaced the starter and solenoid, which fixed the original problem described in this thread. Now it turns over but it still won't start. I replaced the cam position sensor and still no luck. I tried adding oil directly to the upper reservoir (it's been draining down for years), still won't start. Any thoughts on what to try next?
Old May 25, 2010 | 10:44 AM
JamesHajek's Avatar
JamesHajek
Are you getting smoke out the tailpipe and is the tach moving while your cranking??
Old May 25, 2010 | 12:05 PM
Motor2of7's Avatar
Motor2of7
No smoke, no indication of fuel or ignition. I'll have to look at the tach when I get home.
Old May 26, 2010 | 12:21 PM
JamesHajek's Avatar
JamesHajek
Are you getting any tach movement?
Old May 26, 2010 | 05:00 PM
McQween's Avatar
McQween
4wd Low
Mine did that once and it turned out to be high resistance in the valve cover gaskets try scanning it and see what happens .
Old Jun 4, 2010 | 10:23 AM
Motor2of7's Avatar
Motor2of7
Sorry guys, I've been away on business. Yes, the tach does show a reading when the engine is turning over.
Old Jun 4, 2010 | 09:37 PM
fuelman's Avatar
fuelman
Check the filter bowl,is it full? And your full pressure,should be at least20psi at the shrader valve. If all that is ok then pull valve covers and check UVC harnesss'. If ok then get a friend to crank it while you watch for oil squirting out the injector spouts. If any don't have oil coming out you may need orings.
1994F2507.3L
Sep 28, 2016 09:38 PM
bloodspoint
16
Jul 15, 2015 05:49 AM
AMGrulz
Nov 16, 2014 09:51 AM
dbail3
Electrical Systems/Wiring
Sep 18, 2014 07:07 PM
dieselzen
Feb 9, 2011 01:24 AM
