Steve83 has posted or knows the procedure for converting to the newer PSOM speedo. I am alll but certain he has done this. You can reprogram the PSOM six times before it will no longer accept changes. You might check with him. As I understand it, those gears are rapidly becoming white elephants.
Thats what I am talking about....installing a PSOM in place of the existing speedo. Steve83 claims to have done this on his older Bronco and has the info for doing the swap.
'87-up already has the sensor in the rear axle - it's the RABS sensor. I had to cut some plastic to fit it into my cluster, and of course, add some wiring to power it. http://www.webphotos.com/list_photos...&smi=1&a=13217
