1979 spindle help
Old May 17, 2010 | 10:02 AM
eric138's Avatar
eric138
1979 spindle help
I am trying to remove the spindles from my 1979 F150. I have everything else taken off, rotors, steering linkage, but I can't figure out how the spindle comes off. The picture in the Chiltons book is different from what I have. There were some kind of plugs on the top and bottom that had greese fittings in them and that's as far as I got. If anyone has any advice it would be appreciated.
1979 Ford F150
2WD,5.0L
Old May 17, 2010 | 10:23 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Unsrew the plugs with the grease fittings and remove them. Then, about midway between the two caps you just removed there is a nut (11/16") that needs to be removed. This is in the axle, not the spindle. After this is removed take a hammer and hit the stud that the nut was screwed onto and drive it out. This is the retaining pin that holds the kingpin in place.
After the pin is removed, and if you're VERY, VERY lucky, you can now take a punch and drive the kingpin out. Chances are though that the pin is seized in the bore of the axle and won't budge. Plan "B", do all of the above, take a torch and heat the axle to release the pin. Plan "C" Pull the axle and take to a machine shop and have them press the pins out.
Old May 17, 2010 | 10:56 AM
eric138's Avatar
eric138
Thanks alot. I know exactly what you are refering to.
djmichael24951
Mar 6, 2014 08:55 PM
djmichael24951
Mar 29, 2013 02:44 PM
kevin316
Aug 17, 2012 09:08 AM
manveru
Dec 12, 2010 09:23 PM
yellott
Oct 18, 2006 08:20 AM
