i need rocker arm help!
Old May 16, 2010 | 12:03 PM
ty8573's Avatar
ty8573
checking the uvch and decided to check the rocker arms. some will wiggle back and forth and some wont, it doesnt seem normal, can someone help?
Old May 16, 2010 | 01:45 PM
fifthwheel01's Avatar
fifthwheel01
Welcome to FTE.
Did you torque the down yet? If not here's a link to torque info. Hopefully thats all you'll need . If not I'm sure some one else will chime in with more for you
https://www.ford-trucks.com/forums/9...ml#post8857711
Old May 16, 2010 | 01:58 PM
ty8573's Avatar
ty8573
thanks, i torqued them (or tried anyway) my chilton tells me 20 lbs and only one was slightly loose. good now though! thanks
Old May 16, 2010 | 02:03 PM
fifthwheel01
Thats about the extent of my borrowed knowledge. We'll have some real mechanical brains here soon. Did you check to make sure the push rods were'nt loose?
Old May 16, 2010 | 07:19 PM
F350-6's Avatar
F350-6
Completely normal. Stick a breaker bar with socket on the crank bolt and spin the engine. The loose rockers will be tight and some of the tight ones will now be loose. Has to do with normal operation of the valves as the motor spins.
watsobs329nl
Mar 19, 2012 11:15 AM
seafire
May 3, 2010 11:40 AM
CatFlip
Jul 31, 2006 07:58 AM
cobrajet
Nov 11, 2001 08:28 AM
