Vacuum leak...
Old May 16, 2010 | 11:57 AM
Grems4ever's Avatar
Grems4ever
Vacuum leak...
I do believe the van has a minor vacuum leak. Any suggestions regarding where I should start looking?
Old May 16, 2010 | 05:02 PM
gearloose1's Avatar
gearloose1
An old tech trick (gotta be very careful) is to use a propane cylinder, and bleed a bit of propane (take all precautions to have no spark etc around and be prepared to put out a fire).
Go around the vac. lines, and hold at each location, see if the engine picks up RPM briefly.
If it does, you found your leak location.
Confirm it by seeing if a squirt of soapy water will seal it.
Old May 17, 2010 | 05:09 AM
rebocardo's Avatar
rebocardo
Spraying carb. clean can help you find a leak.
Roasted7
Oct 21, 2012 06:04 PM
tractoman
May 30, 2007 09:55 PM
LV Dan
Sep 7, 2004 03:17 PM
xKirkx
1978 - 1996 Big Bronco
Mar 20, 2004 01:24 AM
