Vacuum advance module
Old May 29, 2007 | 12:27 PM
tractoman's Avatar
tractoman
I borrowed a Mityvac to test some things on the truck. My coffee (juice) can vacuum reservoir leaks down a little and so does my vacuum advance unit on the distributor. Should these parts hold steady vacuum and not leak . I am pretty sure the reservoir should hold but I am not sure about the vac advance module. Also, would the reservoir be a vacuum leak with the check valve ahead of it.
Old May 29, 2007 | 05:47 PM
jade79's Avatar
jade79
One way I like to double check the vacuum advance, is to remove the cap and rotor, manually advance the plate with my finger, then hold another finger over the vacuum port opening. It should hold steady until you release your finger. I've seen those hand held vacuum pumps leak down internally. The connection between the hose and nipple on the advance could be a source of a leak as well.
Old May 30, 2007 | 10:56 AM
tractoman's Avatar
tractoman
I was using a good hand pump that does hold vacuum and the hose connections were good. Do these parts need some attention due to the vacuum leakage? It seems the vac advance does and the cannister shouldn't have an impact on performance. Is this correct?
Old May 30, 2007 | 11:52 AM
Mil1ion's Avatar
Mil1ion
Vacuum advance diaphrams are prone to dry out and become useless from breakage.
People rarely think of these parts going bad.
Old May 30, 2007 | 12:11 PM
tractoman's Avatar
tractoman
So will my module have a part number on it or is it based on the model of the distributor so I get the correct unit? What about the vacuum canister? Should I worry about this leak?
Old May 30, 2007 | 01:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
CA only = D4MY-12370-A .. Vacuum Advance (Motorcraft DD-698)
NON CA = D5AZ-12370-A .. Vacuum Advance (Motorcraft DD-714)
D6TZ-19B566-A .. Vacuum Reservoir (coffee can)
Reservoir fits 1976/78 F150/350
Old May 30, 2007 | 02:37 PM
Mil1ion's Avatar
Mil1ion
There are 2 applications for the V/A ....on a 76 460
DD-728 ( fits Dist D5TE-12127-VA)
DD-339 (fits Dist D5TE-12127-ADA , or D3TF-121270-EA,HA
Old May 30, 2007 | 03:22 PM
NumberDummy
DD-728 ( fits Dist D5TE-12127-VA) >> 300 I-6 / section 120; page 14
DD-339 (fits Dist D5TE-12127-ADA >> 351M / section 120; page 20
or D3TF-121270-EA, >> 330 FT engine / section 120; page 20
HA >> 390 FE engine / section 120; page 25
Better check those refs again, Dennis....NONE of these distributors you listed above are for a 460...See the parts catalog section and page numbers for verification. The ones I listed in my above post were looked in the Ford parts catalog by application and are correct.
Old May 30, 2007 | 09:55 PM
Mil1ion's Avatar
Mil1ion
Mine are from the Motorcraft service application catalog
1975-1977
1973-1977
TRucks
mscheel
Jun 1, 2015 09:31 PM
Wayno
Apr 19, 2014 07:48 AM
AggieOutlaw
Jun 15, 2012 07:50 AM
DBGrif91
Jul 23, 2010 05:32 PM
GMan1
Aug 15, 2009 05:34 PM
