i have a 1995 ford ranger the buzzer will not go off the air bag,abs,and check eng lights are all on is there a wire i can cut to make the buzzer go off ???
Wrong question to ask. Ask how to fix the reason the buzzer is buzzing, and why the lights are on. It's not easier to cause another problem, fix the problem you have.
You may have more than one problem. Is your truck a super cab model????
Did the problems come about after some event????
On the buzzer problem, all you may need is a spritz of WD-40 in the right place, so look in the "Tech Info" thread atop this forums thread listing page for the dome light fix.
Also lots of other good links to wrench turning help there, like how to pull your air bag codes.
Most auto parts stores will scan the computer for trouble codes at no cost, so have that done & post ALL of the trouble code numbers.
