Help... Can't Find Right Cam Sync. Alignment Tool.
Old May 15, 2010 | 01:49 PM
bnmc98's Avatar
bnmc98
I have looked everywhere including searching for my aplication (2000 Ranger 4.0) for the right cam sync tool and I cannot for the life of me find one to fit. All I see are up to 98 for the Ranger 4.0. and then my year with the 3.0. The closest I found is the OTC 6483 for 99-02 for explorer and 99-04 mountaineer with pushrod 4.0. (didn't know they came that new with 4.0ohv)
OTC6483 Ford Camshaft Synchronizer Tool OTC 6483 OTC Automotive Mechanics Tools
Is that one I can use?
My problem is for some reason Ford used a 2 pin sensor that uses a variable reluctance pick up not the standard Hall effect pick up for about 2 years on the 4.0 rangers. like 99 and 2000. So mine has that and I can't get it ligned up without the tool. Tried the voltage thing and that did not work. I keep throwing a p1309 code.
Any help would be great. Thanks.
Old May 15, 2010 | 02:43 PM
g_k50's Avatar
g_k50
Does your engine have a label of SOHC on it?
Old May 15, 2010 | 03:02 PM
g_k50's Avatar
g_k50
My 1999 Service Manual lists the Syncro Positioning Tool 303-630 for the 4.0L OHV engine.
Old May 15, 2010 | 03:04 PM
g_k50's Avatar
g_k50
My 2001 Emissions control Manual suggests that the PCM might need to be replaced.
Old May 15, 2010 | 03:13 PM
bnmc98's Avatar
bnmc98
That would suck, can you explain? Are you getting that from the code I am throwing? I just assumed that it meant the cmp was misaligned, which comes up as one of the possibilities for the code.
BTW My engine is an OHV 4.0
so according to your sevice manual this would be the right tool: http://www.spx.usatoolwarehouse.com/.../OTC-6470.html
Old May 15, 2010 | 03:35 PM
g_k50's Avatar
g_k50
DTC P1309 indicates Misfire Detection Monitor is not enabled.
so do the following:
Disconnect the PCM
Connect a digital multimeter
Measure voltage between CMP and PWR GND circuits at the PCM harness connector
Bump engine in short burst with the starter withou starting engine for at least 10 engine revolutions
Does the meter reading swithc between low (less than 2.0 volts DC) and high (greater thatn 8.0 volts DC)?
If yes:
Verify that the CMP is installed correctly. If it is installed correctly replace PCM.
If no:
Replace CMP sensor.
The above technical information is from the 2001 Emission Control Manual.
Old May 15, 2010 | 03:36 PM
g_k50's Avatar
g_k50
Looks like the correct tool.
Old May 15, 2010 | 03:37 PM
g_k50's Avatar
g_k50
This might need a "FORD" service to reflash the PCM
Old May 15, 2010 | 04:06 PM
bnmc98's Avatar
bnmc98
Guess I need to get the tool first and then go from there. The cmp is brand new so I would think that it would be OK.
Is there a technique for aligning the CMP without the tool on a Variable Reluctance sensor? I know about the method for the Hall Effect sensors.
Old May 15, 2010 | 08:24 PM
bnmc98's Avatar
bnmc98
It seems wierd that the tool would not list the 4.0 but only the 5.0 and 3.8. Are you sure that is the right #?
http://www.modularfords.com/forums/s...-fix?p=1277200 The # for the application in here states to use ford tool 303-638
Old May 16, 2010 | 12:56 AM
g_k50's Avatar
g_k50
If the CMP is installed correctly and works correctly that would indicate that the PCM is bad.
Old May 16, 2010 | 07:41 AM
smalltrucker's Avatar
smalltrucker
That first picture of the positioner looks just like this one with the proper description.
Cam Synchronizer Explorer,RANGER, Mountaineer 1999-2002 4.0L 303-638
My 2000 shop manual shows the correct number of 303-638. I have the 303-630 that I got off E-Bay and it is marked 3.8L / 5.0L. Local Ford dealer was kind enough to let me borrow one over a week-end one time. Good luck, hate them kind of problems.
Dave
Old May 16, 2010 | 09:18 PM
bnmc98's Avatar
bnmc98
OK... so I cheated. I just looked at the internet picture of the alignment tool and adjusted my synchronizer to what it looked like and it has been 60 miles and no CEL. I might be good to go. How long does it usually take to trip the CEL with a misaligned CMP? The last few times it came on within 20 miles.
King-bRanch
Ford Truck Parts for Sale
Aug 25, 2016 12:19 AM
HELMUT RONER
All Other Items for Sale
Aug 2, 2016 11:04 PM
milliesdad
2004 - 2008 F150
Feb 8, 2016 03:11 PM
zhigaag
Dec 21, 2015 09:52 PM
nitro3421
Feb 28, 2011 09:40 PM
