Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C Series gauge cluster
Old May 15, 2010 | 10:00 AM
adharvey2's Avatar
adharvey2
The gauge cluster on my '62 C600 is shot. the printed circuit traces are so fractured that nothing works, and any attempt at soldering them is not well received by the 48 year old plastic board.
Has anyone installed a newer instrument panel on their C series? The dash was unchanged through 1990 so I know a new one will fit, but not sure what issues might arise with newer gauges though.
Old May 19, 2010 | 06:34 AM
Wowabunga's Avatar
Wowabunga
I have a 1986 C-800 I just parted out and have the guages for sale for cheep. Will it interchange I've got no earthly idea...
Old May 19, 2010 | 01:30 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
Does it not share the gauge cluster from the 57-60 pick-ups? 57 was the first C series. If so, dakota digital makes a digital cluster that fits the dash. I may be wrong about all of this.
Old May 21, 2010 | 12:03 PM
adharvey2's Avatar
adharvey2
I'd be interested in the entire instrument panel, or just the 5 gauge cluster, whatever.
Could you email me: adharvey@montanasky.net
Looks like this, right?
Thanks
Old May 27, 2010 | 04:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The C Series Tilt Cab was not available with a printed circuit board until 1978, so if your 1962 has one, the cluster has already been swapped.
F Series trucks use different instrument clusters than C Series.
Old May 27, 2010 | 08:02 AM
Wowabunga's Avatar
Wowabunga
I'm looking for a new old stock "superfleet" ac unit for the roof..... anyone seen one. Need sheet metal for step area.
Old Aug 31, 2010 | 08:02 PM
1960camper's Avatar
1960camper
You can check your local Ford dealer they may still have some body parts for the C series I bought alot of the sheet metal for my C series from Midway Ford out of Kansas city,MO. But i would chec local big truck ford dealer which is what Midway Ford isor was
Old Sep 12, 2010 | 08:20 AM
NumberDummy
wowabunga: (1967 C Series) Need sheet metal for step area? What does this mean, you want the running boards?
If so...all 1957/86 C Series used the same ones.
D8HZ16450A (replaced B7T16450B) .. Right Side Running Board-Exterior-before Front Fender / Obsolete
DON'S TRUCK SALES in Fairbank IA has ONE = 800-462-4406.
GREEN SALES CO. in Cincinnati OH has THREE = 800-543-4959.
B7T16450B =
GREEN SALES CO. in Cincinnati OH has ONE.
D8HZ16451A (replaced B7T16451B) .. Left Side Running Board-Exterior-before Front Fender / Obsolete
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
GREEN SALES CO. has ONE.
B7T16451B =
GREEN SALES CO. has TWO.
No other Ford Dealer or obsolete parts vendor has either one.
Old Sep 12, 2010 | 11:09 PM
Wowabunga's Avatar
Wowabunga
Ok Mr. Numbers.... here's a visual of what I'll be needing for the restoration. When you step up into the C-Cab the "well" or the "first step" on both sides , they will need either touched up with welding or NOS sheet metal.
The image is from a Ford Truck Body book from 1964. Your D8HZ16450A/D8HZ16451A running boards are what I need the most and many thanks for the part numbers. Now do I just slap the D8HZ in front of the other numbers ( in light blue on the pic ) to continue my search ??? Are there any better exploded images for the body parts that you've run across or is this pretty much what I have to work with ?
No rush on this project... but I am slowing filling up several boxes with NOS parts for the restoration. Truck is very solid with only a few areas needing attention. This has the sleeper cab... interior is covered floor to ceiling in 1970's thick red **** carpet
Oh... got any 1960's numbers on a black rubber floor mat for this rig ? THANKS...!
Old Sep 13, 2010 | 12:01 AM
NumberDummy
The image is from a Ford Truck Body book from 1964. Your D8HZ16450A/D8HZ16451A running boards are what I need the most and many thanks for the part numbers. Now do I just slap the D8HZ in front of the other numbers ( in light blue on the pic looks more like chartruse to me ) to continue my search ??? Are there any better exploded images for the body parts that you've run across or is this pretty much what I have to work with ?
No, you don't just slap the D8HZ prefix in front of these numbers. It applies to the boards, it may not apply to anything else.
When I look in the OSI catalogs..then I will find this out.
And....basic numbers 00190 & 00191 and 02514 are body part numbers, not chassis part numbers as the others are.
Body part basic numbers require the two additional numbers before the basic number shown in illustrations, like this:
C4TZ9102514A and after looking in the OSI catalog, I discovered that D8HZ6002514A is the replacing part number.
Ford is in-famous for replacing (updating) 10's of 1000's of part numbers every year.
If you don't have OSI (Obsolete-Supercede-Interchange) Catalogs, you may be lookin' for a number that was replaced...sometimes more than once.
Keeping track of these changes was...and still is a ROYAL PITA! Before I post a part number, I have to check and see if it was replaced or not,
If replaced, I list the new and former part numbers.
Old Sep 14, 2010 | 07:44 AM
NumberDummy
D5HZ8310D (replaced C4TZ8310A) .. Right Side Radiator Air Deflector / Obsolete
No Ford Dealer or obsolete parts vendor has either number.
D5HZ8311D (replaced C4TZ8311A) .. Left Side Radiator Air Deflector / Obsolete
D8HZ16506A (replaced B7T16506A) .. Right Running Board Apron / Obsolete
No one has D8HZ16506A
B7T16506A = GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
D8HZ16507A (replaced B7T16507A) .. Left Running Board Apron / Obsolete
No one has D8HZ16507A
B7T16507A = CARPENTER OBSOLETE PARTS in Concord NC has ONE = 800-476-9653.
E0HZ6000190A (replaced B7T9100190A) .. Right Body Front Panel Lower Extension / Obsolete
HIGH PEAKS FORD in Raybrook NY has ONE = 518-891-5560.
E0HZ6000191A (replaced B7T9100191A) .. Left Body Front Panel Lower Extension / Obsolete
COUNTRY FORD TRUCKS in Ceres CA has ONE = 209-541-3673.
GREEN SALES CO. has THREE.
D8HZ6002514A (replaced C4TZ9102514A) .. Right Front Body Lower Pillar & Extension Assy / Obsolete
D8HZ6002515A (replaced C4TZ9102515A) .. Left Front Body Lower Pillar & Extension Assy / Obsolete
No Ford Dealer or obsolete parts vndor has either number.
E4HZ6013010A8A (replaced D2HZ6013010A7A & D3KZ6013010A .. Black Floor Mat-add necessary holes / Obsolete
No Ford Dealer or obsolete parts vendor has any of these three numbers.
Old Sep 14, 2010 | 02:27 PM
Wowabunga's Avatar
Wowabunga
Maybe I'll just stick with the red **** carpet that someone installed in the 1970's and that will solve that problem. I've got a NOS 1980's floor mat in storage and will check to see if that number matches up.... right now there's so much junk piled up in front of the door I can't even get to the attic. I need to start selling some of this stuff.
Your number research help is amazing. There may not be any of some of these parts on dealer shelves but somewhere they may pop up and I'll be looking....!!!
I'm going to drive the C-750 down to Charlotte once restored and give Bobby Allison a ride ( he used to own the hauler in the early 70's ) and you're invited to tag along Bill.
Thanks a Plenty,
Ramblin Randy
Old Jan 13, 2011 | 06:01 PM
clutch58's Avatar
clutch58
no,the instrument panel is completely different on the 57-60 f100-f350.
BEN WHEELAN
Feb 26, 2018 11:29 AM
75BigBlock
Jun 25, 2017 12:11 PM
Brian Ski 44
19
May 31, 2017 06:37 PM
Gary Lewis
34
Mar 17, 2017 03:14 PM
JBronco
1978 - 1996 Big Bronco
Jul 6, 2007 12:31 AM
