Cam for mild performance 460...?
Old May 14, 2010 | 03:00 PM
stefanwlsn's Avatar
stefanwlsn
So I am looking at cams for my 460. It will have the stock heads, performer intake, 600 cfm carb and headers when it is all said and done. I want a noticeable idle, but nothing radical. What duration/lift range should I be looking?
Old May 14, 2010 | 07:06 PM
compman25's Avatar
compman25
Something like this? Comp Cams CL34-235-4 Comp Cams 'Xtreme 4x4' Hydraulic Flat Tappet Camshafts
Old May 14, 2010 | 07:41 PM
stefanwlsn's Avatar
stefanwlsn
Mine is 2wd.
Old May 15, 2010 | 11:47 AM
compman25's Avatar
compman25
It will work in a 2wd too.
Old May 15, 2010 | 12:55 PM
kettle-one's Avatar
kettle-one
The way I understand it, porting your heads will gain you more than a cam swap, and will work better with a cam swap. Also, most any aftermarket cam is going to rev farther than the 600 will breath. Most folks with a 600 cfm carb state the motor gives up at about 4000 rpms. Go to 460 Ford Forum - Powered by vBulletin, and do a ton of reading, lots of 460 builders their and good, honest, helpful information about building or modifying your 460.
Old May 16, 2010 | 12:29 PM
lasthighboy's Avatar
lasthighboy
i run the comp cam extreme 4x4 cam on my 460 w a 600 edelbrock. It is considered an rv cam which makes good low end torque. runs smooth not much lope to it though. Last year it would run 7500 rpm but now i can only get about 6000. everyone tells me a750 would be a much better carb for it, and i have stock exhaust manifolds and unported heads and a weiand stealth intake. Im only running the 600 because i had it off of a 400.
furrby
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 13, 2015 10:13 AM
BBpwer
May 3, 2015 08:46 PM
87classic460
Oct 21, 2014 11:15 AM
75 Camper Special
Jun 24, 2014 01:13 AM
