tranny swap?
Old May 14, 2010 | 01:04 AM
bigmem124's Avatar
bigmem124
tranny swap?
does anybody know if an e4od out of a 7.3 would bolt up to a 6.0? id only do this in light of my money that is not there. thanks guys
Old May 14, 2010 | 05:16 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It will not bolt up. And if it did, how would you get a computer to make it shift?
Old May 14, 2010 | 06:41 AM
bigmem124's Avatar
bigmem124
i would give it some candy
Old May 14, 2010 | 06:54 AM
npccpartsman's Avatar
npccpartsman
I don't know why you'd want the E04D instead of the 5R110 anyway. For the cost of the changeover you can make a bulletproof 5R110. What kind of problem are you having and do you have a COMPETENT tech to fix it. There are some very small things to do to a stock 5R110 that will make it handle a LOT of HP.
Old May 14, 2010 | 07:04 AM
gearloose1's Avatar
gearloose1
You find a automobile transmission software engineer that have the modules from Ford to work around the issue.....
These people are scarcer than $2 bills.
Old May 14, 2010 | 07:56 AM
tex25025's Avatar
tex25025
May I ask why would you want to go from Filet Mignon to ground chuck? I have had many a scary situations with the old tranny, not one with the torqshift and the old tranny was all stock, even when the torqshift was going south because of too much hp, it didn't do what the old one did.
Old May 14, 2010 | 09:52 AM
Lubbockguy1979's Avatar
Lubbockguy1979
The bell housing is different. Your better off to fix what ya got. It would likely take a built e4od to handle what a torqshift would dish out anyway.
Old May 14, 2010 | 10:33 AM
gearloose1's Avatar
gearloose1
Maybe it is like playing piano to water buffaloes.
Old May 14, 2010 | 06:18 PM
bigmem124's Avatar
bigmem124
well its cuz im flat broke and can get an e4od for free it would be temp
Old May 14, 2010 | 06:22 PM
william_04_x's Avatar
william_04_x
Are you a pianist?
Old May 14, 2010 | 06:57 PM
tex25025's Avatar
tex25025
More then likely more temp then you would like to think. I was/am less then pleased with the tranny behind the 7.3, so I don't tend to beat around the bush with my feelings towards that tranny. You haven't lived to you've had to deal wtih Dallas traffic hauling horses with a tranny that takes 1.5 minutes to shift so I can make a left turn to try to beat traffic and that was on a good day.
Old May 14, 2010 | 06:58 PM
69cj's Avatar
69cj
Cheaper and more reliable to do your torqueshift. Plus you wouldn't be happy.
Old May 14, 2010 | 09:10 PM
Lubbockguy1979
it will cost more time and in parts that the free tranny is worth. buy a 500 dollar car that runs and save up for the tranny
Old May 15, 2010 | 01:43 AM
bigmem124's Avatar
bigmem124
thats actually what ive started doing thanks for the patient help there mr. lubbock advice takin
Old May 15, 2010 | 05:24 AM
bismic's Avatar
bismic
You will be much happier with your dcision than if you had found a way to do the mod. The 7.3L tranny's were not really their strong point (personal experience).
