1995 powerstroke
Old May 13, 2010 | 01:01 PM
dventoza's Avatar
dventoza
1995 powerstroke
Im looking at a 1995 diesel f-250 4x4 and was wondering if all 95 diesels were powerstrokes or if some were still idi's? Any problems with the 95 Powerstrokes that are not common with other psd?
Old May 13, 2010 | 01:09 PM
Talyn's Avatar
Talyn
94 was the last year for the IDI buddy.
Old May 13, 2010 | 01:12 PM
dventoza's Avatar
dventoza
Thats what I thought but just wanted to clarify. Thanks
Old May 13, 2010 | 02:32 PM
JamesHajek's Avatar
JamesHajek
Where are you located? i spotted a reg cab 95 this morning on CL in Western Washington for 3k
Old May 13, 2010 | 02:40 PM
dventoza's Avatar
dventoza
This one? sale-s5gmz-1738410166@craigslist.org
Im in south seattle.
What do you think about that truck? worth looking at?
Old May 13, 2010 | 02:47 PM
JamesHajek's Avatar
JamesHajek
you gotta post the actual link. not the email address. If its the white one. I would FOR SURE go look at it. It said rebuilt engine which makes me curious what happened to the original. but its a 5speed which is nice. If i was over on the west side right now, i'd be looking at it!
Old May 13, 2010 | 02:53 PM
dventoza's Avatar
dventoza
oh my bad. 1995 F-250 Diesel 4X4
How do you like your 95 psd? Had any major problems with it?
Old May 13, 2010 | 03:01 PM
JamesHajek's Avatar
JamesHajek
I love my truck. The only thing i see with that truck is it has the IDI radiator in it which means it was probably an early 95. No big deal there. Ford used the IDI radiators on Powerstrokes until they used them all up.
Old May 13, 2010 | 03:03 PM
dventoza's Avatar
dventoza
Is there any worries about caviation on the psd?
Old May 13, 2010 | 03:06 PM
JamesHajek's Avatar
JamesHajek
I have never worried about it. That was mostly a IDI issue. Although im sure there are people on here that will tell you differently. Just use the right coolant and you should be fine.
Old May 13, 2010 | 03:09 PM
dventoza's Avatar
dventoza
ok cool. how does yours start in the ellensburg winters when its not pluged in? I spend a good amount of time in that area in the winter hunting and such and I wont be able to plug it in.
Old May 13, 2010 | 03:24 PM
JamesHajek's Avatar
JamesHajek
It sucked cuz i had bad plugs. Once i changed those i didnt have too much of a problem. Just put new glowplugs in and a new gpr. Then check all your wiring. Shouldn't be an issue if that engine is new though... But just cycle the plugs all the way through and it shouldn't have too much trouble.
Old May 13, 2010 | 03:26 PM
dventoza's Avatar
dventoza
Whats a GPR? Glow plug relay?
By cycle the plugs you mean change them all at once?
Old May 13, 2010 | 03:29 PM
Big Ruth's Avatar
Big Ruth
I have a 1995. It has 140,000 miles. The first morning I tried to start it, I left it outside. It was 12. It started up. It was a little unhappy about it but it started.
I plug it in when its below freezing. I have had no issues. This site is great because I know what to look for when it does start having issues.
Old May 13, 2010 | 03:31 PM
JamesHajek's Avatar
JamesHajek
Yes sir, GPR = glow plug relay. And by cycle them i mean, turn the key to the on position and let them glow for a full cycle or two which can be up to 120 seconds when its really cold outside.. Then you should have no problem starting.
